Replacement Lights
/ Replacement Lights #1
Mahindra 1526, Yanmar 186D
I had no lights, harness or switch. Thanks to HF and ATV LED spotlights I found a solution. If you are a purist/restorer read no further.
ATV spot lights worked in the space. Pulling the hood off made life easier.
Wiring harness is way too big, so if you have wiring-don’t bother.
I like the results and it is probably better than OEM.
/ Replacement Lights #2
I'm more the purist and restorer, yet those silly Stanley P15D25 bulbs are so wimpy to cast any reliable light, even when the machines were new.
Doing a slew of research, mostly on Honda ATVs and on the snowmobile forums using the same headlamps in the 70s and 80s, I found a super really nice halogen replacement.
These are about 4X brighter over the original, and a tad less than the LEDs you put on.
The OE original bulb,
The halogen bulb, HM202,
low beam HM202, just over 300ft distance and illuminating reflective items over 500ft away beyond the road.
HM202, high beam, well beyond 550ft of the entire driveway.
/ Replacement Lights #3
This is the link to the H-F LED Flood lights if anyone wants to upgrade.
This is the best price on the web for the HM202, ROCKAUTO.COM. :love:
  • 12v 35/36.5w
  • OEM Part #'s: Arctic Cat 0409-005 Honda 34901-GJ1-003 Polaris 4032088 Suzuki 09471-12138 Yamaha 5UM-84314-E0-00 Yamaha 5VM-84314-00-00
  • Common bulb for early 70s Japanese motorcycles
Stanley HM202 Halogen 12V 35/36.5W.
OEM ReplacementArctic Cat 0409-005, Honda 34901-GJ1-003, PU K10-1117, Polaris 4030055, Polaris 4032088, Suzuki 09471-12093, Suzuki 09471-12138, Yamaha 1A2-84714-41-00, Yamaha 2GN-84314-00-XX, Yamaha 2GN-84314-00-00, Yamaha 5VM-84314-00-00
This part fits: (click the plus signs to expand)​
Data info on the HM202 Halogen,
/ Replacement Lights #4
And if the LEDs flicker or behave weird or not light up, then look at this first before returning,
Another reason I went with my direction. Overspray on the inside of the lenses.
/ Replacement Lights #7
I'm sure that's the way I'm going on the ford. I have lights that just barley fit but are just to close to my FEL. frame for me. I'm going to make a bracket and add lights like your replacements. Been looking at Grill options.
I use the old style lights In my Yanmar 2000. No complaints there.
I had to replace one of the 4155 light bulbs. 5.49$ Big money were sayin!!! They both still work. Looking at the Inv. 1/28/2009. Fredricks. I ever need them. Already have a R. Serv. light so I'll be looking hard at H.frieght for both setups next time I'm in there!
/ Replacement Lights #8
Once the canopy on the ROPS is done, I'll add on those H-F LED spots. The YM2610 then would have a Deere look to it.
Those are LED spots, do looking long distance out is not effective, yet all around the tractor really near would be totally lit.
One downside I have with LEDs, when they go out, it's so costly to relace with another new one again. A halogen bulb is under $3.
/ Replacement Lights #9
Yup!! HF. El cheapo it will be.
Only have to install 1 and if or when it does go out in the garbage can. Should be a Perfect fit and super easy to make a mounting bracket and install it ;)
6 in. LED Flood Light
I installed a 24 inch bar on my Mahindra on the ROPS (dont put on the upside and have to move like I did) for 25 from A + a trailer plug which also runs my sprayer.
I think the Yanmar has almost as good light But no ROPS to mount.
/ Replacement Lights #11
On the Yanmar lights Mequiar's PlastX works really good. Been using it for Yrs. on the F250 lights and Bug deflector. Just a small drop and any cloudiness goes away. Cotton makeup pad and looks like I just Armour all them. Lasts for months though. You have to rub it in and your see the lens clean up. My lights wasn't that bad but your be amazed what comes off. It may take several times for yours. This is a pic. of when the 63 2000 finally showed up. The lights I'm plannimg on trying to mount it to the Loader frame in front of the steering wheel. 8- 12 inch light option available at my HF. also. Couple body parts and I may paint the 63 ford
/ Replacement Lights #12
Oddly, with Yanmar and all the hype of safety claims against the gray market tractors, it's so common to hear about the Yanmar domestic sold machines missing their ROPS.
There were a few aftermarket companies offering certified ROPS for the machines, then it's gone a bit silent.
One company was the actual OE supplier to Yanmar, Custom Products. So, the foldable ROPS on my YM2610 via Fredricks is a CP made ROPS.
On TBN and other tractor forums, some people have taken a close enough ROPS and welded then just like the CP ROPS to fit their machines. On was done last year or so for a YM186.
/ Replacement Lights #13
The YM2000 is all Org. in the background. From Oh. know all about the Rollover!! Mother was the Kids bus driver. Chained to a fence post and the Throttle linkage was Stuck wide open.... Well it eventually rolled over you Think!! Org. From the Mtns. Of WV. so hills are kind of common. It happens This is true but for people in Waynes World need them that's for sure ;) Shawing>>.
The property I bought it for is completely flat. I only have one field and around the house that I dare to drive it here.
This may be a grey market, Its badged Red but the underside of hood and fenders are orange
/ Replacement Lights #15
The YM186 is domestic. And there are painted industrial yellow/orange for some of the Yanmar domestically sold machines for city and municipal uses. Likewise for the same machines in Deere too.
So, your machine is full legal here in the USA.
Still, a machine can flip on flat land. 3PT bottom plowing and 3PT PHD situations are a cause for it mostly. Other times when brush mowing, a hidden tree stump can cause an upset too. So, use caution when thinking about a snagging issue possibility. The key is knowing your land in great detail and never underestimating it.
And there is also industrial Gray, not to be confused with Gray Market Tractors either.
/ Replacement Lights #16
So can a Convertable. All Vehicles roll over. Wonder how that happens. Foot in gas can't stop quick enough. Linkage get stuck? Problem solved just put a bar over your head!
/ Replacement Lights #17
Before I bought my YM240 I read all the research I could find. One poster somewhere said he looked out his window at some factory and saw the yard YM240 on its side more frequently than it should have been, on paved flat ground. He attributed it to unskilled operators making sharp turns with the loader at full height. These are not very wide and they don't weigh much.
My apple orchard is all slopes, with holes where foxes, coyotes, etc have dug a basketball-sized hole going after gophers. For the YM240 where it would be impossible to climb over the tire as it went over, I needed a ROPS. I bought one as soon as Hoye said they were in production again. (I think my order really got forwarded to Fredricks). At any rate the ROPS is made and certified by Custom Products, the original ROPS supplier to Yanmar-USA.
Lights? The original ones are more than sufficient to find my way back to the barn in the dark. Anything more would be just for fun, with no practical need in my case.
/ Replacement Lights #18
In the same socket the OE Stanley P15D25 fit in, you can now use the halogen HM202. No mods, no splicing, just swap in the bulbs.
In the other thread, my seach began when a bulb burned out and I wanted to buy it locally. Then finding out it's an odd and rare bulb to get. Thus the quest for a replacement and possibly better. On the YTOG, it's common hearing of how many people switched. I only learned it from the Japan motor sports owners as they too needed a replacement.
/ Replacement Lights #19
LB-4155 195 240 276 330 1500 1700 2000 2001 2200 2210 2301 2310 2500 2610 3000 3810 4300 One of my Org. Yanmar lights is Org. never changed that one and the Fredricks 4115 has been in use since 09.
P15D25 is a lower watt bulb. 12V-25/25W and the correct Yanmar bulb LB 4155 is 12V-35/25W a smaller Watt bulb. One of mine is Org. and the Replacement has lasted since 09.
May try the correct Yanmar Bulb you might be surprised how well they work.;)
/ Replacement Lights #20
The Stanley 001-1259 headlamp assembly is used in these YM and Deere 50 models
My Fredricks UTDA YM2610 came with the original Stanley P15D25 25/35W from Yanmar in Japan. See it right here:
The Yanmar p/n is 194155-55810. In the description is the Stanley p/n of A12V 3.4W
I go to Yahoo market in Japan and find, A12V = P15D25 sold by Stanley on the website.
The Stanley bulb dims for the glass diameter is 19mm. Yes, this will fit into the 20.1mm hole.
I used a digit caliper to take these measurements.
When I looked at the Japan ATV and motorcycle cross references from the 60s, 70s, 80s, no 4155 turns up as a replacement. In fact, the 4155 designation is not assigned to any bulb in the mobile 12VDC industry. Fredricks, Hoye and Southern just use this generic 4155 number as an inventory item, not a bulb size classification.
And we now arrive at the modern halogen replacement.
How does the HM202 35W halogens fit in the Stanley headlamp assembly? P E R F E C T L Y. :love:
You can keep the old incandescent bulbs and have dim light using the 4155 stocking number that fits the hole. There is no trace back reference on the Fredricks site to who the bulb manufacture really is. Its just a basic generic.
I'll have 2X the distance and illumination using the halogens.
