Tire Chains for Traction on Turf Tires - Areas Beyond Snow?
/ Tire Chains for Traction on Turf Tires - Areas Beyond Snow? #1
New Hampshire
Kioti CS2220
So, we're new to tractor ownership. Just purchased a little CS2220 with a FEL and mid-mount mower. It has the turf tires, which I think will be fine for most applications and I don't want to tear up the ground if I can help it since we only have a couple open acres right now. All that said, my question is, what would be some recommendations for improving traction when working in the less developed parts of our property? A bit of mud and timber. I was wondering if you could use snow chains on the rear to help in soft ground/uneven terrain? Or is there some other option (besides swapping out the tires). Our main activities will be a little bit of clearing, putting down chips on trails, moving down/cut wood for firewood. The tires are ballasted with beet juice and the tractor is 4WD. Thanks in advance!
/ Tire Chains for Traction on Turf Tires - Areas Beyond Snow? #2
I'd try it "as is".....until you get an idea how what you might need. Some time ago, I had a Kubota BX with turf tires and it worked just fine for my conditions and didn't even need chains in snow. Whereas a later Kubota B model with R4 tires wouldn't function at all in snow. That Kubota got chains and they worked fine for other winter chores such as plowing.
Cheers,
Mike
BTW......rear ballast really helps in most functions....but not necessary when just mowing.
/ Tire Chains for Traction on Turf Tires - Areas Beyond Snow? #3
Chains work great on turfs because the chains won't fall between the tread lugs. Be sure you have clearance between the tire and fender.
/ Tire Chains for Traction on Turf Tires - Areas Beyond Snow? #4
In winter I fit 3/8 inch ladder-style chains on my JD950 rear turf tires. Had to fit extenders to move the wheels out about one inch to clear the fenders. JD advises against chains on the front tires to prevent fouling the power steering plumbing. Tractor with 4wd works fine, even on glare ice. I use the loader to shove back the snow berms when they get too narrow for the pickup snow plow. Chains stay on until late spring as they're like cleats on soft soil and mud. Don't hurt the turf if you don't spin the wheels.
/ Tire Chains for Traction on Turf Tires - Areas Beyond Snow? #5
I never take the ladder chains off the B7200 turfs. Not the Bolens HT-23.
Keeps from spinning on grassy slopes, and doesn't appear to harm turf at all.
/ Tire Chains for Traction on Turf Tires - Areas Beyond Snow? #7
My first tractor - 1982 Ford 1700 4WD. Under heavy snow plowing - it didn't have the weight to have sufficient traction. Even with the R-1 tires. I put on HD V-bar ladder chains - on all four. The improvement was fantastic.
/ Tire Chains for Traction on Turf Tires - Areas Beyond Snow? #8
I have the same tires as you on my Kubota BX2680. I have been stuck a couple of times mowing some of my trails. I just avoid those areas till it dries up enough.
Winter on the other hand is different. I put chains on all four tires.
Dave
/ Tire Chains for Traction on Turf Tires - Areas Beyond Snow? #9
Ladder chains are better then no chains but that is all.
The studded Euro type chain will have much more traction and the ride will be almost as smooth as just tires are.
Ladder chains will be bouncy on hard ground or hard ice.
/ Tire Chains for Traction on Turf Tires - Areas Beyond Snow? #10
You can say that again..........plus....my ladder chains have a noticeable gap where the cam happen to lock.:(
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2014 Chevrolet Tahoe SUV (A59231)
2014 Chevrolet...
