Tie Rod Boots
/ Tie Rod Boots #1
svendawg
Member
Salem, AR
Mahindra 4550 & Mahindra 5155
I tore the tie rod boots on my 4550 and need to replace it. Mahindra wants $150.00 for a replacement rubber boot (ouch) Part L1009100012. Does anyone know of an aftermarket part of an alternative I can use. Rubicon International has the entire tie rod assembly with the boot for $112.00 (currently out of stock) Seems pretty extreme for the boot to cost more than the entire assembly
/ Tie Rod Boots #3
Do you have a picture of one? Dorman sells off the shelf boots for $6-$8 and found at most auto parts stores. Google "tie rod boots" and see if you can find one close. They come in many forms. Or find someone that can make a 3D file and print it out of TPU filament. I've got the printer and filament but no file. :cool:
/ Tie Rod Boots #4
Maybe order by size?
For example:
/ Tie Rod Boots
I need to pull the boot off to get measurement and I'll begin my search.
/ Tie Rod Boots #6
yeah, I have the same situation....on a 4025....it flexes so don't think 3D printing would work. I just used duct tape. If you were to replace, it looks as though it will be a pain to disassemble and reassemble.
Simon
/ Tie Rod Boots #7
I think they make split boots so you don’t have to take it apart to replace them. I assume they are generic and not designed for your tractor. I’ve never used them so I don’t know how well they work.
  • Good Post
Reactions: JJT
/ Tie Rod Boots #8
Make sure the thread direction and size matches.
/ Tie Rod Boots
Here is a picture of the boot. The measurements are on the small side are .73 or 18mm. the large side is 1.51 or 38mm. I found something close on e-bay that I ordered but it is coming from Bulgaria. Due to come around Jan 11 to Feb 1 2024. It's made from silicone so I hope it will work.
The company MTGreen mentioned (polyboots.com) looks to have a close match but they don't sell to private buyers and they are also in Bulgaria. That too bad because it would be a good resource for this type of boots
The Company name on the Boot QH Talbros is a company in India but they seem to be focused on tie rod and steering assembles and not individual parts for the tie rods.
SimpleSimon The disassembly wasn't too bad.
/ Tie Rod Boots #10
Thanks for your post. I am having the same problem with my 4550. The dealer does not sell the boots and I was trying to figure out some way of Macgyvering a fix. It looks like a split boot would work and they are available at several auto parts stores near me at a reasonable price. There are also several youtube videos on how to do it. I will definitely give it a try next spring when things slow down and warm at my place.
/ Tie Rod Boots #13
TPU (Thermoplastic Polyurethane) filament is flexible. It's generally available from 75-95 Shore A and some special types of TPU filaments with Shore hardness down to 40A. I just made an O-ring seal a couple of days ago with it.
/ Tie Rod Boots
Here is an update on my search for a replacement boot for the tie rod on my Mahindra 4550
I found a pair of silicone boots that fit perfectly for a cost of $3.90 plus $5.20 shipping out of Bulgaria.
They took about a month to get here, and I've had them on the tractor for a month testing them out. So far so good. They are not as robust as the OEM boots but their working. I also beefed up the bracket on the guard that is in front of the tie rod to further protect the boot. If anyone is interested in where I purchased the boots, PM me for the info.
/ Tie Rod Boots #15
Good for you. Great detective work!!!
/ Tie Rod Boots #16
I have the same problem with my 2016, 2538. Called the dealer and he said they do not sell just the boots, would have to buy he whole thing, right side was 192.00, left 187.00. I'll wrap it with old innertube and zip tie it first.
/ Tie Rod Boots #17
That sounds better than the duct tape I've been using...
/ Tie Rod Boots #18
I've been meaning to ask this question for a long time.....How come the manufacturer (Kubota in my case) never recommends greasing these tie rod connections in their OE manual maintenance directives?
Cheers,
Mike
/ Tie Rod Boots #19
If they aren't greased they stand to make some big money when you replace them, at least that's the way it seems with Mahindra
JOHN DEERE 1790 - 12R30" / 23R15" VACUUM PLANTER (A64278)
JOHN DEERE 1790 -...
(9) STAMPED INTERNATIONAL FRONT WEIGHTS (A64278)
(9) STAMPED...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
2020 Freightliner M2 106 Altec LR7-56 56ft Forestry Chipper Insulated Bucket Truck (A64556)
2020 Freightliner...
2020 Deere 670GP (A64126)
2020 Deere 670GP...
