Laundry Washing Machine Lint Filter & Septic Field
   / Laundry Washing Machine Lint Filter & Septic Field #21
Viruses don't get any more infectious than hepatitis. The minimum dose is one virus particle. It also is not easy to kill with chlorine.
In this case, I can understand the public health department's desire for subsurface disposal.
I worked for awhile in an area where hepatitis was common (public defecation everywhere, with the resulting rampant fecal-oral diseases, dysentery, typhoid, etc.). One pretty fit young guy felt sick Friday, was ill Saturday, and dead Sunday from hepatitis.
We have septic, and much as I would like to recycle the water directly, I have made peace with running it through the septic field to be recycled (eventually). The upside of a more direct recycle is not worth it to me, but I can understand others arriving at different uses.
All the best,
Peter
The water from our washer, showers, and bathroom sinks all go out to the grey water seep area. No water leaves our 20 acres and nobody from the county ever inspects buildings once the initial inspections are complete. I understand the reasons that you state for the regulations in general, but the grey water system was already here when we bought the place and nobody is exposed except us. To our own wash water.
   / Laundry Washing Machine Lint Filter & Septic Field #22
Sounds like a solution to a problem that doesn't exist, if you ask me.
Microplastics is considered an environmental problem by many people. If you smoke a carton of unfiltered cigarettes daily then you won't perceive any problems.
   / Laundry Washing Machine Lint Filter & Septic Field #23
Same here. When I plumbed the house I have 2 waste drain systems. One that goes to a ditch and one to the septic tank. All the sinks, dishwasher, showers and washer go to the drainage ditch. I built this house in 1996 and the septic tank is as good as it was then. Folks in this part of the country have been disposing of brown water in this manner since running water. But no fear, I'm sure the guvment officials know better.
   / Laundry Washing Machine Lint Filter & Septic Field #24
Hyperbole much?
A swing and a miss.
Guy has a 40 year old septic system, WITH NO PROBLEMS. Now suddenly, there is some "concern" about lint from a washing machine.
Lint? From a washing machine?
Glossing over the empirical data (that's a fancy term for scientific evidence) that the existing septic system, which has been in service for 40 YEARS, has no problems in it's function. After 40 YEARS of service. While it is possible (he didn't say) that the OP has only now, after 40 years, installed his first washing machine, and so just now added the new variable to the mix, I'm taking a leap of faith here that the OP, has indeed been washing his clothes in a washing machine appliance (and not using a rock down at the river) that has been attached to that septic system this entire time (40 year period).
My point?
There are more important things to worry about than this.
   / Laundry Washing Machine Lint Filter & Septic Field #25
Perhaps it's because I do only one load of laundry per week. I've never had problems with wash machine lint. I DO have a filter on the outlet side of my septic tank. I've never had any wash machine lint caught up on this filter. I do pull and clean this outlet filter every six months. It never has much of anything on it.
So....... obviously - - I have very little lint OR it gets caught up with all the other organics and remains in the septic tank.
My house is three bedroom. So my septic system had to ( by local ordinance ) be sized for six people. With only me living here - the system is quite a bit oversized. This fact and that I only do one load per week - probably why I have no lint problems.
   / Laundry Washing Machine Lint Filter & Septic Field #27
It’s not a good idea if there’s a chance for the grey water to contaminate surface waters or flow onto a neighboring property. None of those situations apply in my case.
   / Laundry Washing Machine Lint Filter & Septic Field #28
BTW - just a side note here. Many, many studies have verified - laundry waste water contains the highest load of pathogenic organisms. Much higher than what is called - "black water".
   / Laundry Washing Machine Lint Filter & Septic Field #29
Moved into a 12 year old house two years ago and had the septic serviced...popped the cover off the tank...wow! 8" of grease-slime. Broke it up and pumped it out in minutes...geez, said the guy, that was fast, small tank for three bed, 2-1/2 bath home. I let him know I saw a mention of a two tank system on paperwork. A little probing found the other tank cover...to the first tank of the system. 18" of stiff gunk on top...this tank had never been pumped out, laundry lint was not a factor ;) Filter cleaned, drain field inspected...all good!
   / Laundry Washing Machine Lint Filter & Septic Field #30
If you don't use bleach or high temp water you should at least dry your clothes at high temperature to kill the stuff.
   / Laundry Washing Machine Lint Filter & Septic Field #31
"Many people" also make a hobby out of things to get worked up about. I think of it rather like some of the carcinogen scares 40 years ago. Some scientists fed lab rats overwhelming high doses of various products and the declared those products carcinogenic. Problem was that you couldn't reasonably consume the doses that caused the problem.
   / Laundry Washing Machine Lint Filter & Septic Field #32
Seems silly? Fish and other animals poop in the water? All land animals, including humans, poop in the woods.
Bears as well!
   / Laundry Washing Machine Lint Filter & Septic Field #33
Ironing works, too. I've used it where clothes were sun/air dried, and of course insects laid eggs in the clothes. Insect eggs and the resulting maggots are why I don't air dry clothes any longer here. It is a personal revulsion thing for me, not a particular health issue here. Other places that I have lived, what hatches out would be a threat to your health.
At some level, if you are healthy, and those around you are healthy, and nobody is pointing out objectionable odors, air drying really an issue?
All the best,
Peter
   / Laundry Washing Machine Lint Filter & Septic Field #34
Sure glad we moved out of the Bay Area when I was a kid. We air dry a lot and rarely find an insect on clothes. Never larvae. Only risk is random air raids from passing avians.
   / Laundry Washing Machine Lint Filter & Septic Field #35
All the best,
Peter
Do people actually iron their tighty whities?
   / Laundry Washing Machine Lint Filter & Septic Field #37
All the best,
Peter
What insects lay eggs in cloths except for wool moths?
   / Laundry Washing Machine Lint Filter & Septic Field #38
My neighbor did in Germany. She ironed everything to include socks and t-shirts.
I would say somebody was a little little bit ****….
You can take that anyway you might want to
Looks like this thread went off the tracks!
   / Laundry Washing Machine Lint Filter & Septic Field #40
It always amazes me how people expect a discussion to just be focused on what THEY think the discussion should be!!
Lone Star dump trailer (A55973)
Lone Star dump...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
JOHN DEERE 7210 TRACTOR (A60430)
JOHN DEERE 7210...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
1996 Timpte 46ft Hopper (A56438)
1996 Timpte 46ft...
