/ Share Pics of People Hauling or Towing Something Wrong #19,421
/ Share Pics of People Hauling or Towing Something Wrong #19,422
The only problem with that last set of photos are the guy should have aired that tire up while getting gas. ;)
Just a guess how he got from the gas station to the tree:
He braked hard, breaking the strap behind the the load. That shifted his load forward, lifting his front tires off the ground so he had no steering. While he was still going too fast. Crunch.
And the flat trailer tire loaded more weight on the hitch, adding to that loss of steering.
/ Share Pics of People Hauling or Towing Something Wrong #19,424
Some of these are so obviously generated by Photoshop or similar, that I can't believe they're even up for discussion. These aren't real photos, folks.
Do you have proof they are not? Do you have the original pics? I'm usually very good at spotting fakes, as I've played around with Photoshop quite a bit years ago. No matter how I zoom in or hold my face as close as I can, I cannot definitively claim they are.
/ Share Pics of People Hauling or Towing Something Wrong #19,425
I'm not looking at the photo quality, but the content of what they contain.
The first is a standard cab full-size pickup, which is shown so much larger than the tow vehicle (1980's Nissan?) as to be comical. Have you ever seen a tandem-axle flatbed trailer so small that a standard pickup would completely dwarf it in width, or any mini pickup that would almost fit into the bed of a modern standard body 3/4 ton truck?
The second is a forklift fitting fully within the confines of a 6.5' foot bed. Looking at similar-vintage Toyota forklifts, even the smallest 8FD's are a foot too long to fit into that pickup bed with the tailgate closed. I don't think Toyota made any forklift of that configuration in a similar vintage that would fit into a 6.5' bed with the tailgate closed.
/ Share Pics of People Hauling or Towing Something Wrong #19,426
O Lord, buy me a Ford! Hope that is not a building supply employee helping to lash that monstrosity down:oops::rolleyes:
When I worked in a building supply store, I occasionally offered suggestions or sometimes showed them the way to tighten their rope, but I never touched their line beyond that. The only thing I actually did to their load was staple a flag on the overhang.
/ Share Pics of People Hauling or Towing Something Wrong #19,427
I was thinking about the weight of the now full fifty gallon gas tank in the back of the suburban took away what was left of his steering that got him there. Then because he couldn't turn and the tree stood it's ground, the truck wanted to get off of that trailer in a hurry and it didn't turn either. Good thing the suburban was not a Pinto!
/ Share Pics of People Hauling or Towing Something Wrong #19,428
On the first pic, yes, those old Nissan mini-trucks were quite small compared to a newer 3/4 ton truck. Also, you have the F250 closer to the camera (and taller since it's on the trailer) than the Nissan. Hunters and fishermen use this tactic to make their kill/catch look much bigger since it's closer to the camera.
I'm sure you've seen this picture before...same concept:
On the second picture. That is an electric forklift. You can see the black hole under the seat where the battery slides in/out of. We have one at work. Remove the forks, and it would easily fit in a long bed size wise, at 74 inches long, and 41.5 inches wide (based on a similar model I chose which I think is actually the newer, bigger model)
Maybe this one is photoshopped....even down to the gouges in the concrete...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
1998 JOHN DEERE 120 EXCAVATOR (A62129)
1998 JOHN DEERE...
2014 International Maxxforce DT (A53317)
2014 International...
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
2016 Chevrolet Trax AWD SUV (A59231)
2016 Chevrolet...
