Put My Chains on Yesterday - The Easy Way
   / Put My Chains on Yesterday - The Easy Way #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
These are OFA Eko 9 chains. I like "H" pattern chains for my R1 tires because they can't hide between the tire lugs and become less effective. I mount them using the "drive on" method - it is so easy. It's been shown before but worth repeating I think.
I have a length of rope with a hook on each end. I hook the chains near the center and loop the rope over a set of tire lugs.
Then drive forward, stopping once in a while to make sure the chains are centered.
When you get all the way around the chains are tight and with "H" chains there is plenty of slack over lap to easily hook the centers. More than 6" in this case.
Then when you hook the side chains and close the long cam levers everything tightens up - easy peasy.
gg
   / Put My Chains on Yesterday - The Easy Way #2
I jack the rear of the tractor up in the heated garage, layout the chains behind the tractor and spin the wheels be hand, pulling the chains on as I spin the tire. Easy peasy.
Once upon a time I'd simply throw the chains on the top of the tire, but those days are long gone. I'm running double rings, they easily weigh 100#+ each.
   / Put My Chains on Yesterday - The Easy Way #4
I am trying to figure out why you need chains on R-1 tires, and what is all that white stuff in the picture! Can you tell where I am from?
David from jax
(just giving you guys a hard time, as I have never, ever installed a set of chains during the winter!)
David
I like the home made cab.
:) Thanks ! But the tarp is just my cover that I didn't bother to take off. The tractor lives out doors.
The rest is protection while working in the woods
gg
   / Put My Chains on Yesterday - The Easy Way #7
Well, I guess I learned something today... I always referred to those as "Euro-style" chains. (I have OFA Eko 8 chains on my tractor)
I thought when people said "H pattern", they were referring to Duo-Grip chains.
That's why pictures are good - everyone knows what you are talking about. Names get used loosely and can be misinterpreted. I guess "H" is a more generic name and it would have been better if I called them Euro ?? I would call the ones you pictured Duo chains like the title says ?
gg
   / Put My Chains on Yesterday - The Easy Way #10
I don't burn wood anymore. So my timber work is to maintain the timber. Which I do during good weather. So I never need chains.
Looking at Gordon's pictures make me want to put on a set of chains and go to the timber. I'm guessing that tractor will go wherever you have the nuts to point it with no consideration of soil conditions and/or snow cover.
Excellent tutorial Gordon!!! :cool:
   / Put My Chains on Yesterday - The Easy Way #11
Kk maybe I will try it. I have a couple of slopes to work on that I did not get to before the snow came. My chains are deadly, but what a bucking bronco ride when I drive down the road 500 yards or so to get to the other property!
   / Put My Chains on Yesterday - The Easy Way #12
That's one of the reasons I gave up on the Duo Grip chains and went with the Euro-style/H style chains like what Gordon pictured.
I had Duo-Grip chains with V-bars: good forward traction and good lateral traction. However, operating at anything faster than a walk on harder surfaces (packed gravel or paved roads) made for a rough ride. When driving between properties at "transport" speeds, I thought I was going to shake the fillings out of my teeth and start losing parts off the tractor. If I were mainly operating at slow speeds or on softer ground, they would have met my needs.
I finally switched to the "Euro-style" studded chains (or H style as Gordon calls them). Excellent forward and lateral traction (significantly better than the V-bar ladder or duo-grip styles I had used previously on this tractor) and a smooth ride at any speed.
   / Put My Chains on Yesterday - The Easy Way #13
I also put my "Euro" ice chains on yesterday using the same method GG uses. Sure makes things a LOT easier than trying to muscle them on. My chains are also 9mm but they are the Trygg brand. They don't ride as smoothly as I would like but still much better than the "H" pattern chains I had on before switching over. Night and day difference in traction too. I found that on steep hills the H pattern chains would slip between the cross chains. There was enough gap between the cross chains that the tires would ride on the snow for short spurts.
   / Put My Chains on Yesterday - The Easy Way #14
Dang I guess I should get busy and get the wheel spacers on the little Kioti so I have room for the OFA's I got for the rear of it. Then I should at least get the rears on the NH 8160 also OFA's, then the Branson is saying what about me it gets Aquline Talons on the rear and TRYGG's on the front, I never pulled the Talons off the IH 574 this year. It doesn't move very far as it's primarily on the generator during the summer and fall and winter unless we get an extended outage and storm cleanup is done then the Branson gets the generator.
   / Put My Chains on Yesterday - The Easy Way #15
Trygg does make several different styles. I suppose some of them are smoother riding than others.
Sooner or later, we're going to have to nail down the chain terminology. For Gordon, "H" means the same thing as the "Euro style". I always thought "H" was describing the Duo Grip chains.
   / Put My Chains on Yesterday - The Easy Way #16
I was under the same impression.
   / Put My Chains on Yesterday - The Easy Way #17
Here's a few chain types:
Ladder style: available with cross chains every 2 links along the side chain, or every 4 links with or without "V-bars" for extra traction. (4-link V-bar shown)
Duo Grip: available with or without V-bars. (There is also a variation on this style which adds a ladder-type cross chain between each duo-grip pattern: improves traction and makes the ride a little bit smoother.)
Euro-style: (European Diamond Net) Usually studded (which is more aggressive than v-bars), but I have seen some with just plain chain. There are also some variations on this style, but the basic idea is that there is always a good bit of chain on the ground, and that there is chain on the tread around the entire circumference.
   / Put My Chains on Yesterday - The Easy Way #18
Do you jack up one side at a time or both at the same time? I use the rope method but am always willing to learn a better way.
   / Put My Chains on Yesterday - The Easy Way #19
I jack both tires off the ground at the same time. It takes me longer to attach my bungee cords than it takes to get the chains mounted. Easily under an hour for both chains and ~20 bungee cords per tire, (10 inside and 10 outside). I run my double ring chains tight. Loose chains slapping the fenders drives me crazy.
   / Put My Chains on Yesterday - The Easy Way #20
I've never quite understood the bungee cord thing. They aren't needed to keep the chain on the tire. They aren't strong enough to keep the chain in the same place on the tire.
I've only lost one chain in 35 years of use. The side link broke on the outside.
Very common on the Grader to run 100 miles per snow removal at an average speed of 18 mph with 30K lbs of weight on the four tandem tires. 2 link crossbar chains on 17.5" wide tires.
International 9200 (A56438)
International 9200...
pressure washer, and trailer (A56859)
pressure washer...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
Kuhn FC400RG (A60462)
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
