2004 BX1500 engine randomly dying
/ 2004 BX1500 engine randomly dying #1
twisted_pair
Ontario Canada
Kubota BX1500 (2004)
This first started a couple of weeks ago while cutting the lawn for the last time this season. The engine would randomly die for half a second or so then resume. It did this maybe 4 times in the last 30 minutes of work. It only did it while the lawnmower was operating, so I figure it must be a faulty sensor switch in the PTO.
Yesterday I had the front end load attached and was not using the lawnmower deck and it died once, but I was not using it for long.
Like a good ex- farmboy, I've had the seat presence sensor disconnected for near 20 years now.
I'm sure it must be a sensor failing for poor connector contact after nearly 20 years old. I'm an electronics guy who spend 50 years troubleshoot systems far more complicated than this, but a wiring diagram would help. Is there a downloadable wiring diagram for the BX1500 available on-line? Since its an intermittent random event, I may need to connect a datalogger to capture what is happening when the event occurs.
Thanks
Bruce
/ 2004 BX1500 engine randomly dying #2
My gut feeling (and owning a 20+ year old BX2200) is the shut off solenoid.
I'll PM you a link to the BX2200 service manual. Should be real close.
The BX1500 shut off solenoid I believe works backwards from your BX2200 and most. To shut-down, the solenoid is activated for about 10 seconds to pull a shut-off valve, where most others the solenoid is activated to allow the tractor to run, and deactivated to shut-down.
/ 2004 BX1500 engine randomly dying #5
Question first: When it dies is it a slowing down sputtering death OR is it immediate and sudden and final?
2013 International WorkStar 7400 4x4 Altec AM547 50ft Material Handling Bucket Truck (A61568)
2013 International...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
2011 Takeuchi TB016 Mini Excavator (A61567)
2011 Takeuchi...
2017 Ford F-350 Flatbed Truck, VIN # 1FD8W3G66HEB73643 (A61165)
2017 Ford F-350...
SPRING TOOTH FIELD CULTIVATOR (A62130)
SPRING TOOTH FIELD...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
