Battery powered chainsaw
   / Battery powered chainsaw #691
Got it. Sorry about that. Missed “pho”.
But again, the 088 is a huge 6.3 kW milling saw, way outside the range of the little 2-3 kW / 20“ saws Greenworks is selling. Is there any battery saw on the market that actually competes with the 084/088?
That new saw will take up to a 28" they say. 4.3 kW too ;)
   / Battery powered chainsaw #692
That’s a good size, if it can reasonably pull the chain with the nose buried in hardwood. The 084 I owned was not the fastest saw in the world, with the factory sprocket, but I’m pretty well convinced it could pull .404 chain thru an I-beam. Felt like I should be riding the thing, not holding it!
   / Battery powered chainsaw #693
Had 5-6 084s back in the day. 3 166's 2 3120. 84 was my favorite stock and ported.
Raced the ported ones for fun learning back then.
   / Battery powered chainsaw #694
Those are some serious saws! Most here will never hold a saw much over 60cc. Even a horsepower junkie like me ended up trading my 084 down to an 064 (85cc), just more fun and nimbler, for the felling work I’m usually doing with it. The 084/088’s are awesome for milling, but awful big to lug around in the woods.
Reading this forum, it seems most here are running 50cc saws, and you’ll even find many posts praising the power of little MS 250/1‘s!
I’ve never even seen a 166! Is that a Sachs? Does the damn thing come with wheels and handlebars? VIN? :LOL:
   / Battery powered chainsaw #695
Well 84's were my favorite on gas. Now alky nitro the stroked bored 3140 shined.
Had woods ported 3120 and stock ones too.
   / Battery powered chainsaw #696
My learning hotsaw was the 84 gas cocktail one piped. Both ported.
Piped race ported. Other work saw that guy milled with later on.
   / Battery powered chainsaw #697
Those motors are so big, they make those mid-size bars look almost comically small. For anyone following along, no... those aren't 14" bars! They're just huge saw motors.
Must be like a friggin' light saber through warm butter.
   / Battery powered chainsaw #698
Looking at those saws and thinking back too the 60's with our old blue Homelite I think it was a Zip. Heavy slow hard starting smokey but a dang sight better then the alternative.
My father would drop our firewood and maybe lope off the larger branches, and I'd go along with a double bit axle and delimb and trim. We would keep everything down to about 3 inch in diameter.
Often times skidding logs out to the log yard next to the wood shed to cut up later with the belt driven buzz saw.
Don't miss that a single bit.
   / Battery powered chainsaw #699
Yeah, true dat.
My Homelite Super EZ Auto was 41 cc displacement. My Stihl 084 and xyz123's Stihl 088's are all 122 cc, literally 3x the size of the Homelites!
What the Homelite had going for it was torque. I don't remember the sprocket size, or if they got it through a longer stroke/bore ratio, but the thing would just keep pulling, better than you'd think a 41 cc saw should. They weren't fast, but they did punch above their weight on torque, compared to modern high speed saws of similar displacement.
   / Battery powered chainsaw #700
16" muffler 84 and 20" on piped 84 ;) on those 84's above. 20 on the piped 3120.
16 on this work ported 3120. Also 394 ported using same bar goofing off.
Made a meme from it too.
SDLD25 MINI DUMPER (A58216)
SDLD25 MINI DUMPER...
2016 Isuzu NPR 18ft. Box Truck (A56858)
2016 Isuzu NPR...
ATTENTION PLEASE READ (A57149)
ATTENTION PLEASE...
2021 Toyota Corolla Sedan (A56859)
2021 Toyota...
2158 (A58376)
2158 (A58376)
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
