Is it possible to "clean up" my older generator's power for sensitive electronics?
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #11
Sensitive Electronics such as???
Older Generators such as???
I run Champion Generators at my Cabin. Before going Solar/Gen I ran a larger 4000W which did actually fry a couple of VCR Players, but only on Shut Down. If I unhooked the Power before shut down, all was fine.
Then after Solar/Gen set up, I run a 1200w Champion in the evenings to Top Up my Bank and watch TV.
Well Over 2000hrs of 40" LCD and Blu Ray time, and have never fried any. Even with a 30A Battery Charger kicking in and out while watching.
So, I am not going to warranty a Desk Top or such, but if you are careful, use a Surge Bar, Switch it off before the Generator, and Don't think a B&S Powered Commercial/Construction Generator is the same as a Recreational Generator only Louder. You should be fine.
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #12
My old generator ruined a board on my pellet stove. I now only run electronics with inverter UPS. Check out THD on the generator, or put a scope on it and see how bad it is.
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #13
As you found out it is a good practice to turn off things before shutting down the generator. It is also good to not start up a small generator heavily loaded. Ideally no loads until the generator is up to speed. Loads should be introduced one at a time since startup current demands can overwhelm a generators capacity.
BTW, try to never have your generator run out of fuel during operation.
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #14
The biggest problem with small generators is that they may not do a good job of frequency or voltage control with changing loads. Often they do not have much in the way of speed governors nor the inertia of a larger generators.
However if your older generators are good quality I would not worry about using them. Modern electronics are pretty good at being protected from supply irregularities.The bigger worry from a non stable supply is your old standard motors. Such as the compressor in your refrigerator or well pump.
We have a lot of computers and all the usual home equipment. I've been running them all off a 25 year old 5kw Honda generator during our frequent and often extended power outages. I have not had any electronics fail due to the generator's power. However I don't run the well off the generator as I have a 10k gallon tank that gravity feeds the house.
You can put a UPS in front of equipment that you're concerned about, but you probably don't need it just for protection.
A 7-14kw generator's got enough inertia so it won't slow too much under most loads. Maybe if you're welding or have a big AC unit without a soft start it would.
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #15
I've several older, but well running generators in the 7K to 15K range. But with the increasing addition of sensitive electronics to almost EVERYTHING I'm apprehensive about using them to run my devices.
I had initially thought just slap a UPS in the loop, but now they can be fried by dirty power (or so I've read).
Is there any inexpensive solution short of buying all new generators?
As others have noted, it does depend on exactly what you have now, and what you want to run. Do you know that you have dirty power? If so, how do you know?
Brushed generators tend to make electrically noisy power, as do cheap (and some older) voltage regulators. Generators can also be "dirty" in a variety of ways; unstable frequency, unstable voltage, lots high frequency static and / or harmonic frequencies. Devices are sensitive to dirty power in different ways.
Most electronics will be ok behind one or two high quality surge suppressors; higher joule ratings are better. An online pure sine wave UPS that runs your electronics off of its battery 100% of time is a great way to make clean power, but they aren't cheap.
Larger, older generators tend to make pretty good power because they aren't underpowered, and have a large inertia in the engine and windings to run through large load changes. However, they do have to be in good shape mechanically and electrically. Are they?
Ideally, your home loads should be 80% of the generator capacity at least some of the time. There is also the issue that a large generator serving a small load will burn a lot of fuel per kWh of power, so it is best to match generator size to the load being served.
I think @MattB4 makes some excellent points on generator operation. Start your generator, let it warm up, then add loads one at a time, and try not to make large loads the first or last thing that you add/or remove, and then the same thing in reverse. Letting a generator run out of fuel under load is a great way to generate lots of problems for you.
All the best,
Peter
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #16
One thing to beware of is that some UPSs are not very tolerant of ratty input power. I haven't heard of one getting fried, but they'll often switch to battery and stay there (or toggle back and forth...see below) if the power coming in isn't clean enough. Some have sensitivity adjustments, but they're not always intuitive.
What you're describing is the typical behavior of cheap consumer-grade UPS's, and yes, I have a half dozen of them. They work fine on home power, as they're not toggling back and forth every few seconds. Like you, I suspect the contactor/relay would give out after awhile on one of those, if run on anything with really unstable voltage.
But there are also UPS's that don't toggle, just generating clean sine-wave inverter power from the battery all day long. I never dug into the schematics on them, but assume they must have separated charging and inverter circuits, with the battery used as a large capacitor/isolator in-between. Essentially, they are ALWAYS on battery power.
I have bought these several times many years ago in 3-phase, from Sola, Mitsubishi, and JDS Uniphase. I remember all of them also made single-phase variants. Some of the units I was buying were large enough to power a full lab, but some were also small 6U rack-mount units for powering just a single machine.
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #17
Those are called online or inline UPS. They aren't cheap, but you can occasionally find them surplus from a business or data center remodel.
Like you, I have bought more than a few over the years. I would comment that as the online UPS provides power to the equipment 100% of time, the quality of the UPS pure sine wave power becomes critical. I would not consider buying a unit from anybody but one of the big manufacturers that has been in the business for decades.
All the best,
Peter
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #18
That was it. Thank you for the memory refresher. I was buying these 20 - 25 years ago, for various equipment and laboratories, and do remember now they were called "online UPS's". Never had to buy one for home-scale use, so I have no clue as to the cost of smaller single-phase units, and the pricing that does stick in my memory is all 20 years old now.
I suspect the biggest issue may be finding one with our typical 115+115V = 230V balanced split-phase output.
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #19
Although not thought about much the grid power you get can be rather poor quality. Not as often a problem in the US with the exception of weather related events and equipment failure but other countries deal with some really dirty incoming utility power. I recall from several years back when my Mother took her RV to Mexico and ran off their power. She lost a microwave and also a small TV due to the poor power available at the RV park. She had not problems with running off the RV's emergency generator before this.
Another thing about UPS. Not all of them are PSW. many are MSW. Works fine for many things but not all.
ETA: For fun and to understand what is happening when you use a generator imagine that you are in your car on a flat straight road. You are required to maintain 60mph or your car will detonate into a fiery twisted ball of steel, glass and rubber. You have a small margin of speed above and below 60mph but not much.
Everything is ticking along great until you come to a hill. Going up the hill your speed starts to drop if you do not push down on the gas pedal. (This is analogous to placing more load on the generator and the governor of it reacting). After reaching the top of the hill you level back off and you have to release some of the gas pedal pressure so that you speed does not exceed 60mph. The same thing happens in reverse if you encounter a down grade. If the hill (load) is too much for your engine to power up or the brakes to slow down you end up in trouble.
   / Is it possible to "clean up" my older generator's power for sensitive electronics? #20
When we bought our travel trailer I looked into RV surge protectors. Progressive industries was the brand of choice. We purchased one of these:
I have never thought about using one for a generator since I have an inverter generator but it would be worth a look. They have different sizes and even hardwired options.
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
TANK MANIFOLD (A55745)
John Deere 5100M (A53317)
John Deere 5100M...
54in Loader Fork Attachment (A59228)
54in Loader Fork...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
