New rechargeable work light
/ New rechargeable work light #41
How do they charge
How do they charge?
The flat base sends the charging current through the magnet , the base is plugged into a standard 110 wall outlet.
Also the charging base magnetically sticks to my steel shop wall. There are holes in the base to screw it to a non steel wall.
/ New rechargeable work light #44
Smart electrician brand. Hook, magnet micro USB charger its somewhat of a smart charger cuz I've forgotten it was plugged in for days still holds a very good charge. Paid 20 bucks for it almost 5 yrs ago. It looks like this can take pictures of actual light if you want. I've priced genuine DeWalt brand 20volt lights and was blown away at what there asking for them.
/ New rechargeable work light #46
I think it boils down to application, size, lumens, budget.
I just noticed this one on sale Lowe's, Ace Hardware, etc. USB charging. 10 THOUSAND lumens so probably a football field! Panels all adjustable and fold out then together to carry.
I'd get one except I seriously have 100+ flashlights as it is!
/ New rechargeable work light #50
No hook though? Even a cheap plastic hook comes in handy in my experience with them.
/ New rechargeable work light #52
It's nice to have both options though cuz sometimes I found it's nice to concentrate the light in a specific area.
/ New rechargeable work light #55
This is the work light style I'm thinking would fit our needs best. With USB charging, easy to use on-off switch, adjustable light direction and magnetic base.
Those are the same ones I started out with, they do have a hook. Had 4 of them, not too bad for price but not any where close to same league as the Astro on all fronts. On every one I had after about 2 years of use the female USB connector in base of light lost connection. Little red charging light wouldn’t come on unless I wiggled it. They did get used quite a bit though. I suppose the connecter would last longer with light use and less recharge cycles.
Suit yourself but just be forewarned.
/ New rechargeable work light #56
Here you go or anyone else that might be interested in this cheap durable rechargeable work light unless I got a fluke I'll vouch for it handsdown.
/ New rechargeable work light #58
These seem to work well. Strong magnets
I have a couple of the Harbor Freight version of those lights. Mine are the Braun 500 lumen. The magnet is strong - holds the light in many oddball positions when working on my old truck. Easy to get the light into tight spaces and aim it just where needed.
HF also sells an Icon 800 lumen light of similar design. I haven't really felt the need for a brighter light in my use, but I might consider it if one of my Braun models breaks.
I should add, the reasons I'm looking for new shop lights is two fold. They have improved on the rechargeable type enough that I now like them better. Do have battery ones out there which will be retired in time. Plus my eyes are no longer seeing much in low light. I'm still awaiting on one set of lights but I'll give reviews of them all in time. Thanks!
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
159118 (A60430)
159118 (A60430)
2019 Chevrolet Tahoe SUV (A61569)
2019 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
