Portable Jump Starter
/ Portable Jump Starter #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
It's been a while since I've purchased something like the "jump and carry," a portable battery pack for jump starting cars and what not. It appears that in this era, there are tiny jump starters, small enough to fit in console of a truck and are USB-rechargeable. I'm skeptical of anything I see sold on Amazon these days, assuming it's just some Chinese crap. Am I right in being skeptical, or has anyone used such items with success?
What I'd jump start most often is just a small Kubota garden tractor, gas engine. But, if such a product could also jump start actual real vehicles, that'd be grand.
/ Portable Jump Starter #2
They do work to jump full large vehicles assuming you don't have to crank for minutes. Unfortunately I cannot offer brand advice as it wasn't mine when I saw it used. Guy was a diesel mechanic and said it'd start a semi, started my 3910 just fine.
Hopefully someone else can offer advice to distinguish junk from gems because I'm sure they are not all the same.
/ Portable Jump Starter #3
They sell different amperage ones so get one that fits what you are jumping off, me I purchased a NOCO big enough to jump my diesel pick up and have jumped everything from my truck to my lawn mower they work. I also used it to finish dumping a load of dirt in my dump trailer once.
/ Portable Jump Starter #5
I was a bit skeptical of those L-I jump packs too, but the one my BIL had changed my mind. Not sure the one I have would fit in the console (it's a little smaller than a brick, has a zippered case) but it's done the job. Mostly used to start lawn tractor, snowmobile, etc. but I did use it once to start a 45 kW generator at one of my work sites, so it does have some oomph. Think I got mine on Amazon, a quick check didn't show any the same brand, but a bunch more or less the same thing.
Hard to find anything electronic/electrical that isn't made in China, not all of it's crap.
/ Portable Jump Starter #6
/ Portable Jump Starter #8
Be aware that they are a popular item and often go on sale. Some are safer than others. Lithium Iron is much safer than Lithium Ion.
And if you are invested in any "battery operated" tool line, like Milwaukee or DeWalt 20V max, look to see if they have something that might do with your present bttery packs.
/ Portable Jump Starter #9
/ Portable Jump Starter #11
I have the TACKLIFE T8 Pro 1200A Peak 18000mAh Water-Resistant Car Jump Starter. Seems OK, suppose to should recharge it. It lives in the floor tool box in our Ranger.
/ Portable Jump Starter #12
Based off project farm's video, I did purchase this one for keeping in the Ranger at the cabin. I take it to some super remote places in Wyoming where it might be weeks before someone is close by. So it was a no brainer to get one for a just in case situtation. I have had no need to use it, but I'm sure I will.
/ Portable Jump Starter #13
Like the farm project guy found in his testing these, the claimed power reserve it less than advertised. I figure the same thing when I purchase aftermarket battery's for my makita tools.
/ Portable Jump Starter #14
Practically speaking, these battery jump starters take up less room than a set of jumper cables, provide a source of power without having to have a second vehicle as a power source, and can be taken into spaces where jumper cables won't reach. Eg. you don't have to beg someone to let you jump from their vehicle and it doesn't matter that the hood of your car is at the end of a parking space you can't reach with cables.
/ Portable Jump Starter #15
I agree and they seem to work just fine. Glad we got one.
/ Portable Jump Starter #16
I went with a Noco based of ProjectFarm videos and a demo I got when buying a F800 that had no batteries but the seller cranked it with the Noco multiple times. I’ve used it to start tractors multiple times on a single charge and my generator a few times. I’d really like to get one for each road vehicle but it’s too cost prohibitive.
/ Portable Jump Starter #17
I found it 96% charged after sitting in our truck for about 3+- years. It needs a special wall charger that I can not locate. Maybe needed that was not the best thing........ Update! Found the charger and its doing it now.
/ Portable Jump Starter #18
some of the newer ones charge using a type C USB, which is handy.
Here is the project farm test. I like this guys test videos.
I need an aspirin after listening to that guy for 15 minutes. It's like the old Fed Ex commercials, but at least those were only 30 seconds long.
IRMC High-End Massage Chair (A64047)
IRMC High-End...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
John Deere 5115M Tractor (A64047)
John Deere 5115M...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2020 Ford F-150...
Crabtree 17yd Dirt Scraper (A64047)
Crabtree 17yd Dirt...
