Digging up old asphalt driveway
/ Digging up old asphalt driveway #1
SJJIM
Member
LS XR4150H, John Deere 420C
Hi all, I want to dig up and remove an old asphalt driveway that is pretty alligatored. I have an XR4150. A new LB3104 backhoe should be arriving shortly. Was thinking I could pry up pieces that. Any thoughts?
/ Digging up old asphalt driveway #3
Plenty enough tractor. Asphalt driveways are not typically thick, even if paved over a few times, nothing like concrete anyway. You will probably want some teeth on the cutting edge of your bucket, or something like pallet forks or the like, to assist with prying it up. Good luck and take photos!! We all love photos!!
/ Digging up old asphalt driveway #4
Shouldn't be a problem with the backhoe, you wont be able to do much with the FEL other then picking up and loading the broken piece's.
/ Digging up old asphalt driveway #5
Put a fork in it...
/ Digging up old asphalt driveway #6
Sounds like your good to go (y) thumb on backhoe might come in handy.
Backhoe is coming with a thumb, 9, 12, and 18" buckets. I also have a forklift attachment for the XR.
/ Digging up old asphalt driveway #8
Asphalt isn’t very strong especially when it’s falling apart anyway. Start at the edge and you can easily dig it up.
/ Digging up old asphalt driveway #9
Go easy - FELs aren't generally made to do this type of work. People been talking about bending the cross bars and tweaking the SSQA so be careful. I'd use the backhoe and park the dumpster close to the work area as possible. Can move and dump pieces with you FEL with forks.
/ Digging up old asphalt driveway #10
I like the old fashioned way pry bar blocks and a sledgehammer
Of course dad always said I had more muscle than brains
Makes for a good work out though 🤣🤙🚜
/ Digging up old asphalt driveway #11
If your future plans include repaving you might simply pave over the old asphalt.
Yeah, I am hesitant to do too much with the FEL besides scoop up the broken pieces. I also have a neighbor with a little skid steer I could probably borrow if I wanted.
I have had asphalt guys say it is too far gone to put another layer on, plus, one big portion needs to stay at a certain height.
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2025 DELCO T/A 24FT GOOSENECK TILT DECK TRAILER (A59914)
2025 DELCO T/A...
