How Many Have More Than One Tractor?
   / How Many Have More Than One Tractor? #1
rockinbbar
Gold Member
South Texas
New Holland Powerstar 120, Powerstar 75, New Holland c245
From what I see, the majority of tractor owners here and everywhere else have only one tractor.
I mean more than one that runs, you maintain, and use regularly... (Don't count the old broke down one behind the barn with 2 flats. :LOL: )
Surprisingly, after replacing my 2 previous tractors with newer, more improved ones, I find I have have about the same hours on both new ones.
I'd hate to have to choose between them, if I had to pick only one. I really have a use for both.
How many of you are multiple machine owners? Could you get by with just one? Which one would you pick if you had to?
   / How Many Have More Than One Tractor? #2
I have a BX2200 that I put over 4500 hours on and finally added a bigger LS XG3135H a couple of years ago, now has ~600 hours. I managed with BX for 20+ years but is is sure nice to have the bigger machine. I can't see doing without either. That tough little bugger BX is just too handy for a lot of things.....
   / How Many Have More Than One Tractor? #3
Does an industrial backhoe/loader (JCB) count?
How about my JD 430 (diesel) garden tractor that I use as a mower?
If not, then I only have one. International 1066 with a 15' flexwing to cut a couple fields.
(all three get used but I probably use the backhoe the most)
   / How Many Have More Than One Tractor? #4
Couldn’t possibly get by with one. Had 4, currently have 3, would like a 4th again.
The 4th would just have my CX-15 attached to it and be used only for mowing/snowplowing.
The other 3 for hay farming.
One is always hooked to the big square baler-wouldn’t want it any other way. Another hooked to hay mower. These attachments are not much fun to attach/detatch.
Also have (2) 72” zero turns.
A tracked skid loader/teleskid would be great, too.
Would have to hit it big with $$ to afford the 4th and the tele-skid
   / How Many Have More Than One Tractor? #5
I have a few, I kinda like tractors!
   / How Many Have More Than One Tractor? #6
I have a MX5200 Kubota and a 773 Bobcat Skid Steer. For me it's an ideal combo. Each has its advantages and they can share Bucket and fork attachments. The tractor gets a lot more hours but the SS needed for some mowing and clean up. Does a forklift count?
The 5k capacity CAT is an indispensable tool. These 3 cover whatever needs to be done around the ranch.
   / How Many Have More Than One Tractor? #7
Used to have 3 at one point. Kubota B7000, Toselli 226 and Toselli 340.
Then, I needed a bigger/higher HP one and sold everything to get a single tractor.
And now, I kinda could use another tractor to keep at home, so I didn't have to haul a tractor between proprieties so often. 😅
Maybe someday, I'll find a good deal on one that I can restore and keep around. Just need it to till the orchards for the most part.
   / How Many Have More Than One Tractor? #8
View attachment 832346 View attachment 832347
My buddy keeps a few smaller tractors. Each set up for specific tasks. One has a brush hog mower on it, one has a weed tank/sprayer setup, one is a Ford grading tractor with FEL and box scraper. That one is 50 hp size. But all lack 4wd and so he's on the lookout for another one.
   / How Many Have More Than One Tractor? #9
I have 5 tractors, one skid steer, one mini excavator, and a Ditch Witch RT40 trencher
2 Kubota Grand L6060's one Kubota L5740, one Kubota M4700 that is mostly a spare, and one John Deere 3720
My business is building and maintaining athletic fields, so I use most of them regularly.
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
116 Gallon Poly Fuel Tank W/12V Pump (New/Unused) (A59225)
116 Gallon Poly...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2009 Chevrolet C8500 Dump Truck, VIN # 1GBT8C4B59F409922 (A57453)
2009 Chevrolet...
SULLIVAN PATEK AIR COMPRESSOR (A58216)
SULLIVAN PATEK AIR...
