chevy half ton tranny trouble
/ chevy half ton tranny trouble #1
3gunr
wentzville mo
mahindra 2538 mahindra 2810 cub cadet 7260 massey 255
The tranny in my 2012 chevy silverado went out recently along with 6 other people i know , When i took it to a shop there were ten chevy trucks there all waiting for new trannys, Seems the six speed has lots of issues i had no idea about , I have 176,ooo miles on it, how many of you out there have had tranny troubles on your chevy truck
/ chevy half ton tranny trouble #2
The 4L60E/6L60E transmissions are apparently notorious for having issues as they age; now that's what I've read, my own experiences with the 4L60E were all pretty positive.
Now the one you want is the 4L80E/6L80E in the HD trucks from that era.
/ chevy half ton tranny trouble #3
The 4l80e was a decent trans had it in my used/ abused GMC 3500 dumper doo. Older folks I know told me to stay away from the 60e especially in 1/2 ton plow trucks.
/ chevy half ton tranny trouble #4
Your halfton probably have the 6L80E transmission? I had that in my 2009 Pontiac G8GT, it was a trouble free transmission before it got squashed by a tree falling on it after 80Mph winds.
/ chevy half ton tranny trouble #5
[speaking as a retired gm tech] Each family of tranny has it's own unique weakness over time. Doesn't matter who's brand.
The closest thing to a bullet-proof trans is the Allison IF you don't do stupid chit to the power in front of it.
Problems now are waiting parts availability if you need a pump and convertor.
From the owner's POV, a complete reman is desirable for the Warranty offered (3yr/100k) vs having a local guy do rebuild (??mo/??miles) in case there are issues down the road and where it happens
/ chevy half ton tranny trouble #6
It'd have the 6L60E; the HD trucks had the 6L80E.
Also, sorry about the G8, those were magical cars.
/ chevy half ton tranny trouble #7
I am curious about one thing and that is... Did you EVER bother to change the fluid and / or the filter? I do that as regular service on ALL my slush boxes, no matter what make they are.
One thing I do additionally is, I install a bulkhead fitting in the trans pan if it has no drain (which most don't today).
Don't ever buy a Fords 10 speed either. My BIL was the lead engineer / designer on it and as flakey as he is, I'd never have one.
/ chevy half ton tranny trouble #8
Usually have to drop the pan to change trans filters on the gm 60 and 80s cuz it's internal. Allison does have a external spinner filter but also has an internal one you have to drop the pan to change. Kind of a rebuttal on claims Allison's are bullet proof, dropped my pan changed the internal filter and fluid a month later went into limp mode, was stuck in 4th permanently on a 6 speed auto by now I'm freaking out thinking I royally screwed it up somehow, thankfully it was a bad speed sensor on transfer case which caused the computer to put it in 4th permanently. Easy fix and I can sleep at night again.
/ chevy half ton tranny trouble #9
But not the fault of the trans. End result of electrical issue causing Limp mode. Wasn't in Tennis shoe mode.
/ chevy half ton tranny trouble #10
Still affected trans from performing like it should. Electronic free the mechanical components do seem rock solid though.
/ chevy half ton tranny trouble #11
I thought the GM gas HD trucks had the 6L90e transmission and the 1/2 tons had the 6L80e.
saw an ad for the newest GM HDs and it said the gas HD trucks now have the 10 speed Allison.
/ chevy half ton tranny trouble #12
Also if you need to determine which trans is in your truck the 60s pan was square with 16 bolts the 80 was not and had 17 I believe. I won't go into why I know this but i don't use a torque wrench just a 1/4" ratchet and don't eat your wheaties or use a 1/2" ratchet if you drop the pan.
/ chevy half ton tranny trouble #13
Well a quick Google search tells me that the 6L90E is a heavier variant of the 6L80E used in no straight answer; suffice it to say the 80 was used in most applications it seems. I lived back in those 4 speed models. 🤣
/ chevy half ton tranny trouble #14
An extra plate in all the clutch packs?
/ chevy half ton tranny trouble #15
Allisons are excellent transmissions.. SO LONG AS YOU CHANGE THE FLUID AND FILTER(S) ON THE PRESCRIBED SCHEDULE.
Most slush boxes today have no factory drain plugs but you can retrofit all of them with a bulkhead fitting. My 97 F350 E4OD does because it has a B&M deep sump finned pan on it plus a bung for a trans temp sender.
No substitute for additional fluid either. The high capacity pan (if available) is always a good upgrade. If it takes synthetic fluid, better have your wallet out however, synthetic fluid is quite expensive.
Me, I like to drain the pan prior to removing it for a filter change, much less messy and at least on my E4, I can drain the torque converter as well.
I'm a firm believer in an external fluid cooler (mounted in front of the radiator) as well. Factory installed trans coolers are very marginal at best, almost an afterthought.
/ chevy half ton tranny trouble #16
Yep 👍 excessive heat on a auto trans is your enemy. An aftermarket company makes a larger spin on trans filter to increase fluid capacity and filtering media for Allison's my newer 6 speed Allison has a OEM drain plug. Anyways if you get a OEM tow package make sure it has a trans cooler imo.
/ chevy half ton tranny trouble #18
Do Chevy dealers tell owners that the transmissions are "sealed for life" and don't need the fluid changed? I've run into that with other brands. It's technically true- the original fluid will last the life of the transmission. But that may be a significantly shorter life from what it could be if the fluid was changed.
/ chevy half ton tranny trouble #19
If I had a truck with a 180,000 mikes on it and the transmission went out I wouldn’t be happy but I wouldn’t be surprised either.
/ chevy half ton tranny trouble #20
I would have bought that back from the insurance company and do a body swap. That 355hp in a 4,000-pound car would have been fun to drive. (y) :LOL:
