Propane tank question
/ Propane tank question #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
I got two 100 gal tanks for heating. My furnace is dual fuel so mostly firewood is used. In average 40 to 50 gallons used in the winter. Tanks are rented from local co (Eastern Propane).
The price now $4.97 per gal. That's because rentals and low quantity used. Now the question...
Can I use 2 100 Lbs tanks to replace 100 gal tanks. Would it be direct connection or regulators are different? Can this be done? Can I bring 100 lbs tank to propane station to be refilled?
Any other suggestions? Thanks,
/ Propane tank question #2
100 lb tank is ~23 gallons.
$4.97/gal is huge, strongly suggest shopping around and buying a tank, then you can shop for best delivered price. Around here this time of year I can get $2-2.50/gallon, and that's California prices.
/ Propane tank question #3
Depends on how fast your furnace uses propane. The tank might freeze if there is a high consumption rate. Especially outside in the winter.
Using 2 100# instead of 100 gallons for connections depends on the connection. Maybe the same maybe different, you can place them with a “T” which would be different.
100# can be filled at a station. They get heavy when filled…
My other problem is delivery. After snow falls propane truck can't get up to my long steep driveway. That's why i'd rather do it myself when I need it
/ Propane tank question #5
Look into purchasing a 250 gal above ground tank, probably $1200 - $1500, a 500 gallon would be a few hundred more. Shop around & fill when prices are lowest from whoever gives the best deal while a delivery is possible. Surplus capacity doesn't hurt, propane doesn't go bad.
/ Propane tank question #6
Ideally figure out how much you need for the whole year, get a fill mid-summer when the prices are cheapest. That's the cheapest way to do it long-term, but it's obviously most expensive up-front.
/ Propane tank question #7
I heat my garage/work shop with propane. Also use propane for the gas range and cloth dryer. I have 4 100# tanks.
My locale propane dealer delivers to me , I make sure that I have 3 tanks for him to fill each time. I keep track of the one for the domestic use, will rotate that with others so it stays pretty full all the time.
I don't know much about propane tanks, so sorry if this question doesn't make sense, but
what specs should i look in my current setup to determine if tanks can be replaced with smaller size Is it pressure? Type of regulators? Something else?
/ Propane tank question #9
Stumblehorse hinted at an important factor. Size of tank determines the max withdrawal rate. You need to total all the gas requirements in your house... furnace, stove, gas dryer, etc. The number will be in BTU. That determines the minimum tank size or combination of tank sizes. PA can get very cold and too small tank capacity won't be pretty.
/ Propane tank question #10
First, the size of tank has nothing to do with the internal pressure of the tank. The pressure is solely dependent on the ambient temperature and can be upwards of 200 psi. The pressure is controlled by a regulator and depending on the distances involved there may be more than one regulator. In my case the regulator at the tank steps it down to 10 psi (which is considered hi pressure - for propane) at the house is further stepped down to an 11 inch water column (somewhere around 1/2 psi) The size of distribution pipe matters as well on providing enough gas to meet the BTU requirements.
You will need to add up all your gas appliances to get a total BTU count - this is an important number! You will also need to know the coldest temperature you expect to see. You can then use the tank size you want to use with the ambient temperature to see if it will vaporize enough gas to meet that total BTU count. (Propane gas is in the form of a liquid in the tank with the propane gas above the liquid.)
Vaporization rate
There are charts for the different tanks. Vaporization depends on the surface area and temperature of the liquid propane, so a horizontal tank will have it's highest rate when half full because it has the greatest surface area at that point.
/ Propane tank question #11
Vaporization rate
That's super useful!
Curious why the vaporization rate goes down as the amount of propane in the cylinder reduces - is it because there's less thermal mass and so the the entire mass cools down more rapidly from heat loss of vaporization?
/ Propane tank question #12
It is because of several effects; the surface area of the liquid gets smaller (in a horizontal tank), so the evaporation rate at a constant temperature slows, but the temperature is dropping as the liquid propane evaporates, which means that the rate of evaporation slows further, and the area of the tank in contact with the liquid is getting smaller, which reduces the heat input into the liquid, causing the liquid propane to cool even faster, slowing the evaporation even more.
It is a vicious cycle, and why generators, and other high demand propane devices, don't do well on small, relatively empty, tanks in the wintertime.
All the best, Peter
/ Propane tank question #13
Jotul 370 has a 61% efficiency rating. So the input btu's will be higher than the output btu's.
86 gal x 91,000 btu's per gallon = 7,826,000 total btu's.
7,826,000 / 24,000 btu stove output =326 approx. (326 units of 24,000 btu's)
326 / 4 hours per day = 81 approx. gal.
/ Propane tank question #14
I live in MA and it was 60 degrees on the day of delivery and has averaged in the low 30's since the fill.
Is the gauge messed up? I didn't look at the gauge, right after they filled it.
Would I see that much contraction due to temp? Yes
Any thoughts? I am currently on endless hold with Amerigas.
Propane Volume correction factor is based on a 60° F standard. I believe the tank guage only reads the correct volume at 60° F
In general most liquids when warmed up causes the molecules to speed up and spread farther apart from each other, accupying a larger volume that results in a decreased density.
Conversely, when liquids are cooled (as in the 30 degree outside temp delta in your post) this causes the molecules to slow down and move closer together. Thus occupying a smaller volume and an increase in the density, so it has become more compact. It has the same amount of weight, so the usable amount of energy in the propane has not decreased.
A large Temperature drop does effect how the guage reads and will inidcate that there is less propane in your tank at a lower temperature.
/ Propane tank question #15
If you could find a large enough tank to meet your entire seasonal needs, you could have it filled when prices are at their lowest and you wouldn't need delivery when snow is on the ground.
/ Propane tank question #16
Yep that’s the best solution.
/ Propane tank question #17
a 100 gallon tank at 20' F and at 40% capacity will vaporize up to 235,000 btu/hour. A 100 lb tank has about 22 gallons in it and will vaporize about 79,000 btu when full but much less as the liquid level decreases. Owning your own tank means you can shop it when you need it. You can manifold 100 lb cylinders just like 100 gallon tanks and use the same regulators and POL fittings. If your tanks are next to the house but away from any windows below the top of the tank you probably have a twin stage regulator which takes it from tank pressure to 10psi then to 11-14" WC. Swapping out 100LB cylinders when they are empty and then transporting them to be filled and then reconnecting them is risky. By code a leak check has to be done and documented every time a tank is swapped out or run dry. Not far from here a blacksmith swapped out his own tank there was a fire and his insurance company still hasn't paid out on his claim.
John Deere 700 H Dozer (A62679)
John Deere 700 H...
John Deere 660 Hay Rake (A65640)
John Deere 660 Hay...
ATTENTION! PLEASE READ (A64127)
ATTENTION! PLEASE...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
