SD1840 Engine Rebuild Kit or Parts for LET802C Motor???
/ SD1840 Engine Rebuild Kit or Parts for LET802C Motor??? #1
azdieselguy
Arizona
Shibaura SD1840
Hello, I have a Shibaura SD1840 with the LET802C engine. I'm in need of the parts or a kit to rebuild the motor. The only place I have found to find the parts available is Southern Global Tractor. But their pricing just seems so high compared to different engine kits for different motors. Does anyone know anywhere else I can get the parts? Thank you
/ SD1840 Engine Rebuild Kit or Parts for LET802C Motor??? #2
Did you ever find another place for parts? I’m looking for a gear shift assembly for mine.
/ SD1840 Engine Rebuild Kit or Parts for LET802C Motor??? #3
This is for a Ford 1500. Does it look similar?
/ SD1840 Engine Rebuild Kit or Parts for LET802C Motor??? #4
Not exactly the same but very similar. My Shibarua only has one gearshift in the center. However the damaged parts I'm looking far appear to be the ones in this diagram. I live in Pickens SC and there is a Ford tractor dealer in Anderson that may be able to help me find those parts. If not, I may try Messicks. I sent an email to Southern Global as well which is located in Mississippi. They have helped me before on parts.
Very much appreciate the diagram! BTW, do you still have your Shibaura?
2012 Jeep Patriot AWD SUV (A61569)
2012 Jeep Patriot...
2023 Case TV450B (A62177)
2023 Case TV450B...
2016 16ft. C and S Lawhon 2.5 Ton Pipe Top T/A Utility Trailer (A60352)
2016 16ft. C and S...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2008 Chevrolet C4500 4x4 Altec AT200A 30ft. Bucket Truck (A61568)
2008 Chevrolet...
TANK MANIFOLD (A58214)
