Oil regulator/Oil relief valve
   / Oil regulator/Oil relief valve #1
Skylap
Shibaura SD1840
Hello,
I have a Shibaura SD1840 (LET802C). The other day while driving, all of a sudden the oil dip stick blew out. Obviously there is a high oil pressure in the engine carter. After searching the Internet I suspect that the oil relief valve could be the problem. However I have no clue where to find this valve. Can anybody tell me where to look ? or does anybody have a suggestion what other problem it could be ?
Thanx,
Peter
   / Oil regulator/Oil relief valve #2
Oil dipstick blew out? That would more likely be high crankcase pressure than high oil pressure. I think you may be looking in the wrong direction.
Look for a crankcase breather, vent or filter that might be restricted.
John Deere 950A Zero Turn Mower (A50860)
John Deere 950A...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2015 Craftsman T1800 42in Riding Mower (A48082)
2015 Craftsman...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
