MF1250 coolant/circulation issue help
/ MF1250 coolant/circulation issue help #1
MF231owner
Massey Ferguson 231
A couple weeks ago I bought the compact MF1250 that was a trade in at a local dealer.
First few hours using it I noticed it was running warm so I kept an eye on it. When done I blew debris from the radiator screen.
Second few hours the meter showed cooler than the first time so I thought a was good. Then I noticed a whisp of steam or smoke so I shut it down. Water was steadily dripping from the radiator over flow tube. I'm guessing it was hotter than it showed because it wouldn't even attempt to turn over even after sitting 30min and me filling up the radiator (took 3/4 gallon). It did crank and start about 2 hours later.
Today I made sure it was full of coolant and used I for maybe 20 minutes before seeing another whiff of steam/smoke right as I was parking it.
Now I've got the sheet metal off it watching it run and basically it seems like once it warms up and builds pressure it starts sending the fluid out of the over flow. I don't think its circulating right. I can say the coolant/water looks nasty so I'm going to drain it out and flush it a time or two.
Thoughts?
/ MF1250 coolant/circulation issue help #2
Suggest you buy or borrow a pressure test rig for the radiator. Around $50 on Amazon with adapters for wide variety of radiator necks. See if the cooling system will hold pressure (can be cool for this test.) If not, you probably have a blown head gasket. Don't bother draining and flushing.
You have a huge issue in that it will not turn over after one of these incidents. My first guess is that symptom is a water lock in one or more cylinders due to the blown head gasket. With some luck that is all it is. Having bought it that recently the dealer should fix it. Even with no written guarantee the dealer owes you a fix in my view. Very worst case a shared cost of repairs.
It did the no crank once. Dealer is sending me $1k partial refund to correct whatever is going on.
  • Good Post
Reactions: JWR
/ MF1250 coolant/circulation issue help #4
pull the dipstick and oil fill cover. examine both of them for any grey/white coloring.
Could I have gotten lucky and it was something simple with the fluid? Drained and refilled with water with the intent of just flushing it. I've been letting it running for 15+ minutes fluctuating between 1k-1.5k RPM with no over flow, no smoke/steam, and the temp guage steady between the T and E.
Maybe I spoke too soon. Shut it off and a little smoke came from the engine.
I'll need to double check with the manual but I believe the fill tube and dipstick tube are the same on this model. It's jet black so probably needs replaced. But I believe that's a good thing in my case because white and frothy would point to a head gasket problem right?
/ MF1250 coolant/circulation issue help #9
correct.
another way to tell is run up to thermostat opening and watch recovery tank for bubbling. prob need ot be around 2K rpm to see, is hard to tell that way due to setup probably but its another tool to use.
Drained the water and it was still really dirty. Almost tea like.
/ MF1250 coolant/circulation issue help #11
yeah find way to hook pressure tester up. I suspect head gasket. that locking, even though only once, is telling.
is tester hooked up and not holding MAY be able to use stethoscope on valve cover and hear something...can;t say for sure.
/ MF1250 coolant/circulation issue help #12
Before suspecting a blown head gasket I would check the thermostat and water pump. Not the same, but I had an old car that behaved the same way when the water pump was not pumping.
To check the pump, start it cold with the radiator cap off. You should see the coolant moving, especially if you raise the RPMs. You can also try squeezing the upper hose, should be pressure resistance. If the pump is working then I'd move on to the thermostat.
If you have a blown head gasket and you have antifreeze/coolant you might be able to smell it in the exhaust depending on how bad it is.
/ MF1250 coolant/circulation issue help #13
pressure tester would also show that.
its a good tool to have around, just broke mine so gotta replace :(
I've got the parts manual for it. Thinking about replacing the radiator cap and thermostat just because they're cheap and probably original. It is a low hour tractor though with only 600 hours.
I'll also do the above recommended this evening to see if it could be the water pump.
Anyone know if like Autozone or Advance loan a tool program would have a pressure tester?
/ MF1250 coolant/circulation issue help #16
think thats location specific, have borrowed one from one in one town and town on other side of me did not have one.
/ MF1250 coolant/circulation issue help #17
In my sometimes humble opinion I do not think that the problems you describe can be attributed to a water pump, a thermostat or a radiator cap or any combination of them.
If you are in close working relationship with a repair shop (auto or tractor) they might be willing to loan you a pressure test kit overnight or something. If you have a way to move the tractor to them they might even run the pressure test for you for darn near nothing. This is not a hard one. I bought mine thru Amazon. This one costs $48. Good for virtually any radiator you will ever encounter.
Completely different behavior cold starting it a few minutes ago. Within a few seconds I could see the water rising (had the cap off) and eventually start flowing from the over flow tube. I couldn't see any signs of water flowing through the system. Within 5 or so minutes the water was pretty warm though and Within 10 minutes it was warm enough to see vapor coming from it. Not hot enough to burn my finger.
Squeezing the tube didn't offer much resistance but did visibility raise the water level (cap was off)
/ MF1250 coolant/circulation issue help #19
that this one? the ZJERYL GULL 18pcs
I have saved in list to purchase
Local Advanced Auto has a tester I'll grab tomorrow. Basically you buy it then get a refund when you bring it back. Theirs is a ridiculous $270 though lol
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
