Loaded tires filled with....antifreeze?
/ Loaded tires filled with....antifreeze? #41
Put windshield fluid in mine, it's been in there about twenty years without a problem. Hope I didn't jinx myself...:unsure:
/ Loaded tires filled with....antifreeze? #42
That sounds great!
Do they drive the same? Are they more prone to flat spots if they're parked a long time? If you wear the tread out, how do you change the tire (or do you have to replace the whole wheel)? I suppose the foam is made of bubbles that are actually pressurized a bit as the chemicals react during installation, so, do they gradually get softer as the years go by? Does the foam settle during installation such that the low spot is permanently heavier, or do they perhaps have to jack the wheel up and rotate it to mix things uniformly?
Inquiring minds, etc etc...
/ Loaded tires filled with....antifreeze? #43
I have heard, don't know first hand, that the foamed tires are very rough riding since there is no give to the sidewall anymore and that the tires have to be cut off the rims. Also heard sometimes the rims are not salvageable.
As I said no direct experience...
I use windshield washer fluid, have for years with no issues or problems so far.
/ Loaded tires filled with....antifreeze? #44
could always use wheel weights.... bolt on bolt off never goes bad
/ Loaded tires filled with....antifreeze? #45
The place I am buying my tractor from says that they load the rear tires with antifreeze. Is this okay or should I be telling them no? My last tractor I had tubes installed and had them filled with calcium chloride.
last couple of times I had my JD changed or fixed it was with beet juice. Also the comment about rusting with calcium is true as well. I'm in NJ so not super cold, but why not use it anyway.
/ Loaded tires filled with....antifreeze? #47
I have my rear tires loaded with windshield washer fluid. Works great, not quite as heavy as water per gallon, but adds weight and doesn't freeze. Also cheaper to buy 50 gal than other fluids.
/ Loaded tires filled with....antifreeze? #48
Foam installed correctly is fantastic. It is two part and cures inside the tire. I had approximately 80 machines using it in my district at one time and had very few problems and never had a rim unusable. It is expensive and we eventually moved to airsoft style tires. I have a personal tractor with the rear tires foam filled. They weigh approximately 800# apiece and don't ride much different than my steel weighted pneumatics. The one problem with fluid weight is it's power robbing characteristics. I switched a 4430 JD from calcium to steel weights one time and the power difference was startling.
/ Loaded tires filled with....antifreeze? #49
That sounds great!
Foam is misleading. It’s more like solid rubber. It’s a 2 part process that’s mixed and once it is it reacts and hardens. They typically don’t get flat spots but I have seen it start to dissolve when the tires get severe cuts to let water in. When the tires are worn out you have to cut them off with a sawzall. It’s also quite expensive to get done. A local shop said $250 each to do my skid steer tires. I imagine the rear tire on a tractor would be over 1k. The skid steer tires run 80 psi of air and don’t do much cushioning anyway but filling a low pressure tire makes it ride quite a bit worse.
/ Loaded tires filled with....antifreeze? #50
At work, a new Deere 644 wheel loader had it's tires foamed. They took all 4 wheels off and laid them on level ground to be foamed. The foam had to cure so they were left alone over night and put back on the loader the next day.
I also operated 4000 & 6000 pound rated rough terrain forklifts. Occasionally I would operate one with foamed tires. It did ride harsher and it was quite noticeable when moving a light load that had loose banding. The load kept moving around on the pallet when going over small bumps. With aired up tires I didn't have to be so gingerly with the load.
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
TANK MANIFOLD (A58214)
2014 Caterpillar CB24B (A60462)
2014 Caterpillar...
(INOP) MASSEY FERGUSON 451 TRACTOR (A59823)
(INOP) MASSEY...
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1990 Lufkin...
1605 (A57192)
1605 (A57192)
