Is a fully discharged battery now junk?
/ Is a fully discharged battery now junk? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I mistakenly fully discharged the battery in my MX 5100 Kubota. It was a replacement likely made by Interstate. The battery was so dead it even tripped the 50 amp main fuse and I didn't know it could do that.
Anyway, I've been slow charging that battery but I have the feeling it's no good after a full discharge like that. Anyone know about this?
/ Is a fully discharged battery now junk? #3
Ive fully discharged batteries-even 2 of them- in larger tractors and they always recharged for me.
/ Is a fully discharged battery now junk? #4
I've discharged a new battery, charged it back up and it came back full. Been lasting 5 years now
Wow, thank you all for the voice of optimism.I've bought a lot of batteries this year and don't need any more.
It must be an old wive's tale that fully discharged ruins a battery. Or maybe that was in the olden days. These days I charge batteries just before the cold starts and I've had great luck with longevity.
/ Is a fully discharged battery now junk? #7
Fully discharged from slow leak is ok 1ce or twice & maybe 3 times. High discharge can swell/ruin the plates, especially if water level is way down. Using distilled water is best but hardly anyone pays any attention. Mineral water == slow short circuit. Plus, high charge rate bubbling puts acid on the case top so another slow death/drain. Some batteries can last 20 years. some last 2 years depending on how careful and respectful you are with them. No battery: no tractor is how I respect them.
/ Is a fully discharged battery now junk? #8
Only one real way to find out, charge or jump it and see what happens.
I needed the tractor so put a spare in and the discharged battery is on a 3 amp slow charge "smart" modern charger. I never understood boiling the cr*p out of them with a high amp fast charger.
I'll let it slow charge longer and then see what happens. All good to know.
/ Is a fully discharged battery now junk? #10
Discharged batteries start to oxidize the lead plates. Leaving batteries discharged for extended periods is definitely bad.
Single time and it was charged fairly quickly….may not be a certain death sentence.
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2018 New Holland C227 Compact Track Loader (A61307)
2018 New Holland...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
Giyi-D39 QA Trencher (A60463)
Giyi-D39 QA...
Deere 335P (A53317)
Deere 335P (A53317)
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
