Finishing mower - help needed
/ Finishing mower - help needed #1
Brailey Man
Massey Ferguson GC1725m
Purchased an old 2 bladed 48" finishing mower. No name badge. The included picture is not mine but is it exactly. I am trying to find a manual, belt diagram and the original spec for the belt. It works fine except for the belt popping off every ten minutes. So I know something is not right with the belt. Thanks for any and a help on this. I should add that mine does not say Kubota on the side.
/ Finishing mower - help needed #2
Be sure to check the spindles to be sure they are tight and not sprung. They can also cause the belt to jump off. Ken Sweet
Thx. I will check the spindles.
/ Finishing mower - help needed #4
Check your pulleys also and the guards against the pulleys
If the pulley wobbles you can replace the bearings
Also the zerk on the spindle more than likely will not grease
the bearings because most bearings are sealed and it would
take a lot of grease just to get to the bearing as the spindle is
hollow. You can get a needle for your grease gun to actually
grease the bearings by lifting the seal on the bearing
willy
willy
Thx heaps. I have set aside some time to check spindles and Pulleys. Any idea on original manufacturer?
Checked the spindles and pullys and they seem in good shape - little play or worn sides etc.
/ Finishing mower - help needed #6
This company has about everything you could possibly need for
you deck:
willy
you deck:
willy
Thx for the supply tip. Sadly I am in Ontario and between the shipping and border duty, items balloon to four times the original price. Yes I have been caught with that a couple of times and am more wary about it now.
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
Cast Iron Anvil (A61574)
Cast Iron Anvil...
24in pin on excavator tooth bucket (A61307)
24in pin on...
John Deere Worksite Pro RS72 (A64119)
John Deere...
2008 Ford F-350 9ft. Stake body Flatbed Truck (A61573)
2008 Ford F-350...
