Delvac tractor fluid
/ Delvac tractor fluid #1
Brady D
Southern Middle Tennessee
Ford 1910, Case farmall 95, John Deere 317g
I’ve recently changed my hydraulic fluid and used Delvac tractor fluid however I’m now concerned it may be bad since it is not new holland brand. Has anyone used it or have any knowledge? I used it in my 1986 ford 1910.
/ Delvac tractor fluid #2
Tractor brands do not produce their own branded oils, they are made on license by major manufacturer. You should be golden.
/ Delvac tractor fluid #3
New Holland Ambra line is made by Petronas. That what I use on my tractor, Petronas MTF10W30 for the transmission.
/ Delvac tractor fluid #5
It's probably better than whatever you took out. I did a fluid change on one older tractor with Walmart UTF and zero issues several years later.
Definitely is better. the original
oil in it had some water contamination.
/ Delvac tractor fluid #7
On a 1910, at this point, any decent brand name oil is good!
/ Delvac tractor fluid #9
I’ve been using Delvac hydraulic fluid in my Ford 1215 HST since 1995. Also been using NAPA filters for the same length of time, no issues whatsoever, it’s very good oil.
I also use it in my Kioti.
/ Delvac tractor fluid #11
I use it in my Case backhoe. The Case stuff seems to handle moisture better but is about twice the price.
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
2011 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2011 Dodge Ram...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
