Injector leak
/ Injector leak #1
Brady D
Southern Middle Tennessee
Ford 1910, Case farmall 95, John Deere 317g
Ever since I had the fuel filter changed the 3rd injector has been leaking fuel out of the bolt that holds the fuel line to the injector. I have it as tight as it will go and it still has a slight leak how can I stop the leak? Would the plumbing thread tape work?
/ Injector leak #2
I don’t think i would use anything like that. Just take it back off make sure it’s clean, and keep your fingers crossed
/ Injector leak #3
Are you sure it’s the injector line leaking and not that return line? Thread sealer won’t help a flare fittings. Take it back apart and make sure the seating surfaces are clean and free of damage.
/ Injector leak #4
There is no bolt there. Are you referring to the nut on the injector line itself? If so, and you think it's as tight as it will go, then do this. Loosen it back up. Jam it down tight. Loosen it again and jam it again. You will see the wrench will go a little bit further the second time than it did the first time. Do that three or four times, then start it back up and see if that helps.
/ Injector leak
Yes I meant the nut
/ Injector leak
Not the return line replaced them recently and they have worked flawlessly
/ Injector leak #7
Chances are you have it seating slightly out of line of where it has worn in for the past 20 years or so. Harry's suggestion should do the trick.
/ Injector leak
When you say loosen it do you mean to completely loosen or just back it off a few turns?
iDrive TDS-2010H...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
2007 Nissan Altima Sedan (A61569)
2007 Nissan Altima...
