Stuck in gear until engine is off, Ford 3600
   / Stuck in gear until engine is off, Ford 3600 #21
Around here clutches don't get stuck unless they get wet as in rain wet or wash your combine radiator out with water wet (long story). Not condensation wet..
Around here clutches get stuck from lack of use. A lot of tractors are equipped with mechanisms to lock the clutch in a disengaged position. Even more warn the operator in the manual about this possibility if storing the tractor.
   / Stuck in gear until engine is off, Ford 3600 #22
Friends, I read this thread. How a clutch plate of friction material fuses to a flywheel with rust is a mystery to me. I am an idiot and more than that I have a certification in it. Henry took this in mind when he designed the 3600. It is stupid simple and anvil tough.
The Ford 3600 clutch and the 50HP MF of the same era have a superb English live clutch and there are two clutch disks in there. One for the PTO and the other for the drive line.
In the bell, only a few parts can wear out, as if by design they are surrounded by other parts so substantial, it is unlikely that those are broken, narrowing down service complexity. So much so that in my 1979 machine it is almost impossible to even see wear on the beefy parts, due to the quality of material in the gears used by Ford at that time. The other parts not so beefy are few and in fact, wear items.
Allow me to describe these parts by the symptoms when they fail.
1. Throwout bearing - There is a throwout bearing and if it is warn there could be a noticeable vibration felt in the clutch pedal when you push it in because you will be compressing this hockey puck diameter bearing and the rollers within it, if bad, will be grumbling.
2. Clutch pedal light - No resistance means linkage is broken or the wishbone that pushes a shaft that pushes on the clutch fingers is broken and this means the clutch will not disengage.
3. Clutch fingers worn. The fingers at 120 degrees work together to overcome clutch spring tension clamping down on the clutch plates. One finger may become misadjusted or fall off before the others fail. If you feel a slight pulsing of power in the driveline or implement it is due to the clutch not grabbing the clutch plate with equal force all the way around.
4. Seals leaks. There are two seals and two bearings on a splined shaft between the clutch housing and the transmission. It is vital that these seals do not leak oil into the bell housing via the rear splined shaft. If oil gets by the seal it will end up in the clutch housing and on the clutch plated and the plates will slip or the friction material will get soaked and prematurely disintegrate. Metal on metal grinding or slippy clutch then metal on metal grinding over the course of the season. If gouged by clutch plate rivets, your clutch plate will need replacement not resurfacing, and your English plate gets replaced by a Chinese or Indian one of inferior metallurgy.
If you have these problems, not spitting the tractor to identify the problem will only increase the cost of repair. I had a coolant leak and had to split. What I found were some minor problems that some seals, a few bearings, a little hardware and some new clutch plates were able to solve for a few hundred bucks, and I mean few. Yes the split was a hassle, but these issues demand a split anyway, so why not do it before having to throw in more parts? Afterwards my clutch worked great and I had the confidence to work my tractor like Henry intended.
   / Stuck in gear until engine is off, Ford 3600 #23
The combine that I had to take the clutch apart on to free it up wasn't rusted. It was like you had glued the friction plate to the pressure plate. There wasn't a spec of rust on it. I had to take and hammer a flat screw driver between the plates to get it to release. All the owner had done was wash out the radiator and the water ran down the drive belts into the clutch housing. (The clutch is on the transmission and not the engine on a MF 750 combine.) It sat for a few days and then the clutch wouldn't release.
2021 Ford F-350XL (A57148)
2021 Ford F-350XL...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
2013 ISUZU NPR STAKE BODY TRUCK (A58017)
2013 ISUZU NPR...
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
2012 MACK GRANITE - GU713 (A58214)
2012 MACK GRANITE...
