Heard of this grease fitting?
   / Heard of this grease fitting? #1
Mike1955
Kubota
It called a Gaint button head fitting. It’s supposed to grease top roller on a tract style tractor. I guess it’s the only way to “lube” them. Some use heavy oil some use grease
   / Heard of this grease fitting? #2
Yes, I had that style on my crawlers. I still have the proper grease gun tip for it somewhere.
I like them as it doesn't require to hold the grease gun hose so it doesn't leak everywhere like the other common style of grease zerks.
   / Heard of this grease fitting? #3
I'm assuming this is what you are referring to;
using this fitting on a grease gun;
   / Heard of this grease fitting? #4
Not as common as the zerk everyone knows but not rare either.
That’s it! I thought it might help somebody because I looked a while before I found it. I even ask the Cat dealer here and the young person who I was talking to did not have a clue as to what I was needing. On my Cat tractor I just have them on the big top rollers I think on both ends. My U series rollers don’t take anymore grease there are no fittings on them. Thanks for the reply
OK now where do I buy double ought grease? And does it come in tubes. The person I saw had a little jug with a pump lever on it. I think it’s a lock and lube product
   / Heard of this grease fitting? #6
Corn Head Spindle grease. Napa, Deere and Tractor Supply can get it, but only in liquid.
Button zerk used on older field discs too.
I have the pump can and button head coupler still
   / Heard of this grease fitting? #7
I get it at Deere since they are the only ones that carry it locally.
   / Heard of this grease fitting? #8
The button head type grease nipple is often used in high pressure situations With a compatible gun
This was the first I had ever witnessed. I kept wondering how to grease the rollers with nu alimite Research told the tale but I think they are only on these vintage machines.
   / Heard of this grease fitting? #10
Many valves have button head grease fittings.
2019 Generac MLTS-1 2.4kW Towable Light Tower (A49461)
2019 Generac...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
