Heard of this grease fitting?
   / Heard of this grease fitting? #1
Mike1955
Kubota
It called a Gaint button head fitting. It’s supposed to grease top roller on a tract style tractor. I guess it’s the only way to “lube” them. Some use heavy oil some use grease
   / Heard of this grease fitting? #2
Yes, I had that style on my crawlers. I still have the proper grease gun tip for it somewhere.
I like them as it doesn't require to hold the grease gun hose so it doesn't leak everywhere like the other common style of grease zerks.
   / Heard of this grease fitting? #3
I'm assuming this is what you are referring to;
using this fitting on a grease gun;
   / Heard of this grease fitting? #4
Not as common as the zerk everyone knows but not rare either.
That’s it! I thought it might help somebody because I looked a while before I found it. I even ask the Cat dealer here and the young person who I was talking to did not have a clue as to what I was needing. On my Cat tractor I just have them on the big top rollers I think on both ends. My U series rollers don’t take anymore grease there are no fittings on them. Thanks for the reply
OK now where do I buy double ought grease? And does it come in tubes. The person I saw had a little jug with a pump lever on it. I think it’s a lock and lube product
   / Heard of this grease fitting? #6
Corn Head Spindle grease. Napa, Deere and Tractor Supply can get it, but only in liquid.
Button zerk used on older field discs too.
I have the pump can and button head coupler still
   / Heard of this grease fitting? #7
I get it at Deere since they are the only ones that carry it locally.
   / Heard of this grease fitting? #8
The button head type grease nipple is often used in high pressure situations With a compatible gun
This was the first I had ever witnessed. I kept wondering how to grease the rollers with nu alimite Research told the tale but I think they are only on these vintage machines.
   / Heard of this grease fitting? #10
Many valves have button head grease fittings.
197390 (A50459)
197390 (A50459)
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
71052 (A49346)
71052 (A49346)
