Feb 26, 2011 / 1510d front axel drain plugs #1 P pops21 New member Joined Jan 18, 2011 Messages 7 My dad is changing the fluids on his 1510d. The front axel has a drain in the middle and what looks like drain plugs on the ends of the axel on the bottom beside the wheel. Are these drain plugs too?
Feb 26, 2011 / 1510d front axel drain plugs #2 alvanko Gold Member Joined Mar 10, 2002 Messages 398 Location Hinckley , Ohio Tractor Yanmar YM186D & Ford LGT14D Dixon Z BX2200D Kubota Yes,,,,,
Feb 26, 2011 / 1510d front axel drain plugs #3 jerrybob Super Member Joined Mar 2, 2010 Messages 8,246 Location USA Tractor yanmar 186D....JD LT180....DR Brush Cutter Open all the plugs or you're not getting all the old fluid out. :thumbsup:
Feb 28, 2011 / 1510d front axel drain plugs Thread Starter #4 OP P pops21 New member Joined Jan 18, 2011 Messages 7 Thanks for the replys. We opened all the plugs to drain, then filled it back up.:thumbsup:
Feb 28, 2011 / 1510d front axel drain plugs #5 silvertramp Gold Member Joined Feb 24, 2010 Messages 388 Location W. MA. Tractor Yanmar 276D Recheck the fluid level. It takes time for the fluid to work it's way thru.
Mar 4, 2011 / 1510d front axel drain plugs #6 MJPetersen Veteran Member Joined Feb 23, 2007 Messages 1,255 Location Warsaw, Poland Tractor YM 1510-D Check frequently as it can take a couple of days of casual working it for the gear oil to flow out the the knuckle of the left side. Mike
Oct 2, 2023 / 1510d front axel drain plugs #7 tomas995 New member Joined Oct 2, 2023 Messages 1 Tractor Ym 1510d kiek skysčio reikia įpilti?
Oct 2, 2023 / 1510d front axel drain plugs #8 California Super Star Member Joined Jan 22, 2004 Messages 16,873 Location An hour north of San Francisco Tractor Yanmar YM240 Yanmar YM186D tomas995 said: kiek skysčio reikia įpilti? Click to expand... Google translate said: "Lithuanian detected - How much liquid should be added?"
Oct 3, 2023 / 1510d front axel drain plugs #9 careyo63 Elite Member Joined Jan 6, 2012 Messages 2,809 Tractor 77 Yanmar YM2000 63 Ford 2000 I think your right. 1500D 3.2 Qts. 90W
Oct 3, 2023 / 1510d front axel drain plugs #10 R runningbird Gold Member Joined Oct 12, 2005 Messages 299 Location Gisela, AZ Tractor yanmar 1110d ,fx28d or about 3 liters.
