1510d front axel drain plugs
   / 1510d front axel drain plugs #1
pops21
My dad is changing the fluids on his 1510d. The front axel has a drain in the middle and what looks like drain plugs on the ends of the axel on the bottom beside the wheel. Are these drain plugs too?
   / 1510d front axel drain plugs #2
Yes,,,,,
   / 1510d front axel drain plugs #3
Open all the plugs or you're not getting all the old fluid out. :thumbsup:
Thanks for the replys. We opened all the plugs to drain, then filled it back up.:thumbsup:
   / 1510d front axel drain plugs #5
Recheck the fluid level. It takes time for the fluid to work it's way thru.
   / 1510d front axel drain plugs #6
Check frequently as it can take a couple of days of casual working it for the gear oil to flow out the the knuckle of the left side.
Mike
   / 1510d front axel drain plugs #7
kiek skysčio reikia įpilti?
   / 1510d front axel drain plugs #9
I think your right. 1500D 3.2 Qts. 90W
Kubota B21 (A57148)
Kubota B21 (A57148)
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
1996 International Water Truck with a Caterpillar Engine (A56435)
1996 International...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
