TYM T474HC at the top of my list to buy
   / TYM T474HC at the top of my list to buy #21
Pictures please.
   / TYM T474HC at the top of my list to buy #22
Took delivery of the TYM T474HC on Friday 09/08/2023. :)
Nice! Congratulations. I think you made a good choice for the money. I looked long and hard at buying new and this was my choice too. What was the total cost when delivered?
Tractor with FEL and bucket, R14 tires was $32,700. 3rd function added $999, and double rear remote with detent added another $644. Pallet forks were and additional $1090.
   / TYM T474HC at the top of my list to buy #25
You've added all the things I added too, I installed the 2 rear remotes myself. I made a video of it at the same time, in case someone else would be as adventurous?
   / TYM T474HC at the top of my list to buy #26
That would be interesting to see and help someone decide whether to do it themselves or have a dealer do it.
Well, here is a question I have. Does TYM mornally include that orange triangle sign that you are supposed to put on back of slow moving vehicles? I didn't get one with mine.
   / TYM T474HC at the top of my list to buy #31
No, haven't sat on or driven one yet. But having never sat on or driven another tractor before, I would have nothing to compare it against. I think I will have to adapt to anything I would buy.
Yes, I have been thinking the same thing about that backhoe. I am thinking a grapple and flail mower might be money better spent right now. I can always buy the backhoe later on if I find I really have a need for one around here.
But tell me more about that "laneshark".....
I've had my t474 for just over a year now. Only 80 hours on it but have put it through the ringer moving/elimination logging debris from our land. I have the HST, which I'm glad I went with over the Kioti DK4710, which was about $3k more. Just recently added a 60" Titan Hydraulic Shift Flail mower which is a game changer. Serves as my mower and bushhog all in one since it eats up to 3" diameter material. Good luck with whatever you chooose.
   / TYM T474HC at the top of my list to buy #32
The SMV (Slow Moving Vehicle) triangle reflector is required by law for any motorized self propelled tractor that travels at less than 25 mph, is what I was told by a Washingotn State Patrolman.
Was also told that this went into affect nationwise in 2016?
Supposed to be mounted from 2' to 6' in height above the ground.
So read the citation.
   / TYM T474HC at the top of my list to buy #33
I call BS. Not you, but the patrolman. State laws, not federal. OSHA has standards regulations on what signs look like and recommend the 25 mph thing. Technically, you are supposed to remove it if you are off road, but visible from the road. OSHA can mandate that for businesses that fall under their jurisdiction. That all being said, I think most, if not all states have adopted similar regulations for consistency.
For the original question, I didn't get one with my tractor or my UTV. Tractor is less likely to see any road time. UTV will run along our county road...max of about 3/4 of a mile. I doubt the speed limit exceeds 25 mph.
Well, here is a question I have. Should I be able to use the joystick to raise and lower the loader AND roll the bucket (or in my case the pallet forks) at the same time? Basically move the joystick to the "corners" of travel and activate both functions concurrently?
   / TYM T474HC at the top of my list to buy #35
Mine won't.
   / TYM T474HC at the top of my list to buy #36
I don't know about TYM, so take this for what it's worth. To make such a movement on my Kioti I have to feather it just right; it's not nearly as large a sweet spot as my old Deere had. Perhaps you have to find that real tight and right spot?
   / TYM T474HC at the top of my list to buy #37
I can do it a bit. I figured failure is as likely my problem. I think it may be as you say some have a narrower space where both move.
   / TYM T474HC at the top of my list to buy #38
I can, but it takes a practiced hand to find the sweet spot. It doesn't do it fast, but it will. It helps to have the rpms up to 1800-2000.
   / TYM T474HC at the top of my list to buy #40
I did not get one either :(
CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
CATERPILLAR M322D...
2018 Chevrolet Impala Sedan (A59231)
2018 Chevrolet...
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
