Bought A Used King Kutter 60" Tiller And It Broke.
/ Bought A Used King Kutter 60" Tiller And It Broke. #1
wirlybird
Gold Member
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
Just got this tiller yesterday and started tilling with it today and it broke. Rotor stopped turning. Tiller had about 5-6 hours on it so very little use.
After pulling it apart I find that the splined shaft that is inserted and welded to the rotor shaft broke at the weld.
Inspecting it shows the weld had almost no penetration on the splined shaft and was doomed to fail. I have a feeling this has been an issue for them.
Hoping my welder friend can fix this up and I can get back to tilling.
Yea, I'm just an amateur welder and I can see it is poor.
No penetration into the splined shaft.
We'll see how she does after a repair tomorrow!
/ Bought A Used King Kutter 60" Tiller And It Broke. #5
Do you think the previous owner broke it and then stuck it back together with that poor repair? Seems coincidental.
/ Bought A Used King Kutter 60" Tiller And It Broke. #8
Looks more like a bead of something squeezed out of a tube. JB Weld maybe? I don't really see how a welder could produce that.
You wouldn’t typically weld the end on a shaft like that. Even when expertly done it will still cause problems with metal fatigue and tolerance problems.
/ Bought A Used King Kutter 60" Tiller And It Broke. #9
From the looks of it, I'd say it was 5 or 6 VERY HARD HOURS.... :rolleyes:
Yeah, looking at the paint, it looks not much better than my 22 year old tiller that I’ve used annually.
/ Bought A Used King Kutter 60" Tiller And It Broke. #10
EXACTLY. No heat discoloration on the parent metal and to obtain a huge weld bead like that, there would be. There is none. Not welded at all.
/ Bought A Used King Kutter 60" Tiller And It Broke. #11
If it didn’t come out if a tube, then maybe it was some kind of thick flexible rod that was bent around the shaft and then heated with a torch. I just don’t see any sign of the puddling and flow that a welder would produce.
Very strange.
I can get a better picture. It is likely a machine weld or not welded by a human!
Saw a couple videos also about changing the grease seal there and those tillers were welded also so seems to be how KK does it.
/ Bought A Used King Kutter 60" Tiller And It Broke. #13
Can you pull the stub shaft out of the tiller tube? Grinding down much of the old weld before welding would allow a nice small and strong bead. I'm thinking that the stub shaft may be a dissimilar metal which may have been some of the issue. Or, maybe the stub was ice cold and that could also be part of it. I would use a rod that is for dissimilar metals.
/ Bought A Used King Kutter 60" Tiller And It Broke. #14
That's not a weld - it's a Decorative Edge Bead!
I'm with others - No sign of any heat in the shaft. Something ain't right. Unless the place it was welded on is now hidden inside the yellow part so we can't see it??
/ Bought A Used King Kutter 60" Tiller And It Broke. #15
Don't feel bad, you aren't the first person to break a KK tiller. I do custom tilling and I had a guy call me and hire me to come till his field. He added that it was full of stones and I said no problem.
When I got there, he had two king kutters behind his barn, both with the side gears blown and he said his rocks did it, and YES he had rocks.
Anyway, I got it done for him and he was a happy camper!
SR
SR
Yea, KK got back to me and said they see this and it is usually related to an improperly adjusted slip clutch.
Can't deny that logic but I think this would have broke over time anyway.
What tiller to you like for a 5 footer?
/ Bought A Used King Kutter 60" Tiller And It Broke. #17
Howard or Kuhn, get one rated for a little higher than the pto hp of your tractor and have it for life.
One of my Howards has over 2,000 acres on it, and it still has all the original bearings, sprockets, gears and even the side drive chain.
SR
/ Bought A Used King Kutter 60" Tiller And It Broke. #18
A friend had a little 110 volt flux-core mig machine that would produce nice looking welds, but had virutally no penetration. That would be my guess on that weld.
/ Bought A Used King Kutter 60" Tiller And It Broke. #19
OK. But that's not a "nice looking weld." Doesn't even show signs of the material being melted.
/ Bought A Used King Kutter 60" Tiller And It Broke. #20
Year ago we would say that came out of a can labeled CS or Chicken Sh--.
New/Unused Landhonor Air Impact Wrench (A61166)
New/Unused...
Miller Millermatic 212 Auto-Set MIG welder (A63118)
Miller Millermatic...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
UNUSED WOLVERINE QC7-26-12.5G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE M-SB42 42" MINI ROCK BKT (A62131)
UNUSED WOLVERINE...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
