Bought A Used King Kutter 60" Tiller And It Broke.
/ Bought A Used King Kutter 60" Tiller And It Broke. #1
wirlybird
Gold Member
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
Just got this tiller yesterday and started tilling with it today and it broke. Rotor stopped turning. Tiller had about 5-6 hours on it so very little use.
After pulling it apart I find that the splined shaft that is inserted and welded to the rotor shaft broke at the weld.
Inspecting it shows the weld had almost no penetration on the splined shaft and was doomed to fail. I have a feeling this has been an issue for them.
Hoping my welder friend can fix this up and I can get back to tilling.
Yea, I'm just an amateur welder and I can see it is poor.
No penetration into the splined shaft.
We'll see how she does after a repair tomorrow!
/ Bought A Used King Kutter 60" Tiller And It Broke. #5
Do you think the previous owner broke it and then stuck it back together with that poor repair? Seems coincidental.
/ Bought A Used King Kutter 60" Tiller And It Broke. #8
Looks more like a bead of something squeezed out of a tube. JB Weld maybe? I don't really see how a welder could produce that.
You wouldn’t typically weld the end on a shaft like that. Even when expertly done it will still cause problems with metal fatigue and tolerance problems.
/ Bought A Used King Kutter 60" Tiller And It Broke. #9
From the looks of it, I'd say it was 5 or 6 VERY HARD HOURS.... :rolleyes:
Yeah, looking at the paint, it looks not much better than my 22 year old tiller that I’ve used annually.
/ Bought A Used King Kutter 60" Tiller And It Broke. #10
EXACTLY. No heat discoloration on the parent metal and to obtain a huge weld bead like that, there would be. There is none. Not welded at all.
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2025 MMS MS36C (A60463)
2025 MMS MS36C...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2021 CATERPILLAR 302.7DCR EXCAVATOR (A62129)
2021 CATERPILLAR...
2019 DITCH WITCH FX25 PORTABLE VACUUM TRAILER (A59823)
2019 DITCH WITCH...
