Woods RD 7200 on Ford NAA?
/ Woods RD 7200 on Ford NAA? #1
OrtisEvans
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
I bought a used Woods RD 7200 finish mower to replace my old KingKutter 72" finish mower. In attaching the Woods to my 1954 Ford NAA tractor, I found that the hitch pins on the Woods are 3 inches farther apart than on the KingKutter. Result: The anti-sway chains were too short and my old stabilizer bars don't fit. I removed, reversed, and replaced the hitch pins so they point toward each other as seen in the photo. Still, no way to attach stabilizer bars.
Am I doing something totally wrong in this setup? Before I go to the work of cutting the PTO shaft, I'd like to know if I am attempting the impossible.
Thanks and Regards
/ Woods RD 7200 on Ford NAA? #2
Need swing checks to make sure arms don’t hit pto shaft. My RD7200 mower new came with one pin inside and one out so I cut a little more to right side which is fine. On Kubota B26.
My Ford 860 had sway bars outside of the lift arms. Check chains inside.
/ Woods RD 7200 on Ford NAA? #3
If the pin spacing is 26", if so then the stay bars should fit same as any other Cat 1 implement. If just cannot get them to fit properly they do make adjustable bars.
Thank you. I finally set the pins pointing outward, attached the mower, attached the sway bars, and it all fits. Yes, I should have thanked you much sooner.
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
1762 (A58375)
1762 (A58375)
2017 International HX620 Quint Dump (A62613)
2017 International...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
