Woods RD 7200 on Ford NAA?
   / Woods RD 7200 on Ford NAA? #1
OrtisEvans
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
I bought a used Woods RD 7200 finish mower to replace my old KingKutter 72" finish mower. In attaching the Woods to my 1954 Ford NAA tractor, I found that the hitch pins on the Woods are 3 inches farther apart than on the KingKutter. Result: The anti-sway chains were too short and my old stabilizer bars don't fit. I removed, reversed, and replaced the hitch pins so they point toward each other as seen in the photo. Still, no way to attach stabilizer bars.
Am I doing something totally wrong in this setup? Before I go to the work of cutting the PTO shaft, I'd like to know if I am attempting the impossible.
Thanks and Regards
   / Woods RD 7200 on Ford NAA? #2
Need swing checks to make sure arms don’t hit pto shaft. My RD7200 mower new came with one pin inside and one out so I cut a little more to right side which is fine. On Kubota B26.
My Ford 860 had sway bars outside of the lift arms. Check chains inside.
   / Woods RD 7200 on Ford NAA? #3
If the pin spacing is 26", if so then the stay bars should fit same as any other Cat 1 implement. If just cannot get them to fit properly they do make adjustable bars.
Thank you. I finally set the pins pointing outward, attached the mower, attached the sway bars, and it all fits. Yes, I should have thanked you much sooner.
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
UNUSED AGT 3 PT 82" ROTARY TILLER (A51248)
UNUSED AGT 3 PT...
UNUSED FUTURE ML32 - 32" HYD MULCHER (A51248)
UNUSED FUTURE ML32...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
