Looking to purchase a tiller for a small garden plot I have (approximately 20x30).
Fairly small garden for a tiller.  However, if you are affluent probably the best choice.
Following are cheaper implement options.  You would have to inquire if they will properly fit the dimensions, especially lift height, of a BX Three Point Hitch.
Keulavator Frame, 3-Point Cultivator Frame, Cat. 1
Item #51946
Product Overview
The Keulavator™ frame, sold only at Agri Supply®, is a 3-point tractor attachment that can be customized to shape, ridge, bed and help cultivate your garden. This frame is constructed of sturdy tubular steel with solid welds for durability. The Keulavator frame has category 1 lift arms and two tool bars that are 15-3/8 inches long. The tool bars will accommodate IHC-style wedge clamps and bolts. Based on your bedding needs, clamp assemblies can easily be adjusted for a minimum row width of 31 inches to a maximum row width 52 inches. Please view the attachments below.
- Specifications:
- For explanation, see video below
- Keulavator Frame
- Frame only
- 3-point cultivator attachment
- Lift arms: Category 1
- Not compatible with Quick Hitches
- Comes with 2 pins 105549
- Outside to outside dimensions: 56 in.
- Tool bars: 1-3/8 in. diameter x 15-3/8 in. long
- Tool bars accept IHC style wedge clamps and bolts
Also available at Agri Supply®, are the attachments you need to build your custom cultivator. Each attachment is
sold separately.
				The Keulavator® is a customizable 3-point cultivator frame Garden Bedder for making or bedding rows on your small farm. Design your own Keulavator® today.
					www.agrisupply.com
