2020 RK 24 Noise when rolling
/ 2020 RK 24 Noise when rolling #1
Frontloader9
Bristol Va
RK 24
Tractor has 400 hours on it. It has started making an odd noise. Does it in high or low range as well as 2wd or 4wd. Doesn't matter if I am turning or going straight. The noise honestly sounds like popcorn popping. I can actually feel it on the floor board of the tractor but not the steering wheel. I left the tractor on the trailer one day in 95+ degree weather and when I started it, it didn't do it. When I start tractor in barn and move it, it is loud. It does seem to quiet down and completely stop when tractor is warm. I called my dealer, they said bring it in. They said it was probably a wheel bearing. They replaced both wheel bearings as well as the fluid. However, this did not fix tractor. Same problem still exists. I get it. The simple answer is just let it warm up. But I actually use this thing for work. I don't want to be 45 minutes from home and have a break down. I've already lost a box blade customer because tractor sat at dealer for 3 weeks. Thanks in advance for the help from you folks that know much more than me.
/ 2020 RK 24 Noise when rolling #2
Check to be sure ALL WHEEL mounting bolts/nuts are tight
/ 2020 RK 24 Noise when rolling #5
Any chance you could post a video for us? Does the noise change with rpms? Motor mounts, exhaust (+brackets) all good?
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
PALLET OF HOG CREAT PANELS (A64278)
PALLET OF HOG...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
2024 CHUBBS GT-612/60 1T/A 12FT DUMP TRAILER (A67148)
2024 CHUBBS...
JOHN DEERE 6605 TRACTOR (A65054)
JOHN DEERE 6605...
