Adding backhoe to 1983 ford 445c loader
/ Adding backhoe to 1983 ford 445c loader #1
bvahjen
case430
Looking for some hints on hydraulic hook up to add a backhoe attachment I got for my 445c. I don’t see anything labeled PB on the loader valve although there are two unused ports on top of the valve. Any hints appreciated.
/ Adding backhoe to 1983 ford 445c loader #2
When I was a dealer, I sold a Ford 764 backhoe that was made for the 545/445 skiploaders. Here is the schematic of the plumbing. This can be found on New Hollands’ parts lookup under 764 backhoe.
So, it does look like it can be done with the stock loader valve. Thanks!
/ Adding backhoe to 1983 ford 445c loader #4
Did you ever go ahead with a backhoe for your 445C? The loader valve does not have a power beyond, but a backhoe could be added with a little bit of plumbing depending on the backhoe you install.
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
Caterpillar TH255C Forklift (A63688)
Caterpillar TH255C...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
F-150 4WD (A63689)
F-150 4WD (A63689)
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
