Adding backhoe to 1983 ford 445c loader
/ Adding backhoe to 1983 ford 445c loader #1
bvahjen
case430
Looking for some hints on hydraulic hook up to add a backhoe attachment I got for my 445c. I don’t see anything labeled PB on the loader valve although there are two unused ports on top of the valve. Any hints appreciated.
/ Adding backhoe to 1983 ford 445c loader #2
When I was a dealer, I sold a Ford 764 backhoe that was made for the 545/445 skiploaders. Here is the schematic of the plumbing. This can be found on New Hollands’ parts lookup under 764 backhoe.
So, it does look like it can be done with the stock loader valve. Thanks!
/ Adding backhoe to 1983 ford 445c loader #4
Did you ever go ahead with a backhoe for your 445C? The loader valve does not have a power beyond, but a backhoe could be added with a little bit of plumbing depending on the backhoe you install.
New/Unused Landhonor Power Rake (A65583)
New/Unused...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
Striker Slide in Spreader Box (A62679)
Striker Slide in...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
