Soft cab enclosure for winter.
/ Soft cab enclosure for winter. #1
kioti guy 69
Okanagan BC
Ck20s
Does anyone know the name of an aftermarket soft cab brand for kioti? I see kubota has one.
Or has anyone made thier own?
/ Soft cab enclosure for winter. #2
Welcome aboard! If you do a search you'll be able to see a number of examples of DIY soft cabs that should be generic enough to adapt. I recall seeing a number of them made from either old golf cart roofs or electrical conduit frames with golf cart canopies for cabs.
/ Soft cab enclosure for winter. #5
Actually not getting anything from the search,tried diy,soft cab.
Try those, might need to call to make sure they fit your specific cab. Be mindful, these plastic clear materials have way of collecting water droplets and fogging up very easily. Not easy to wipe them off either...so if you are thinking about it for the Winter be ready to have a solution to deal with that.
/ Soft cab enclosure for winter. #6
Branch out to Google and search "DIY Tractor Cab" "Golf Cart Tractor Cab" and "Home Built Tractor Cab" There are even YouTube vids with some.
After seeing the shortcomings of soft cabs, I built a cab from steel and glass for the last Kubota. It cost me around $1200 and lots of hours.
/ Soft cab enclosure for winter. #7
Very nice cab. Did you post a thread here on your build?
/ Soft cab enclosure for winter. #8
If you need something to keep you warm long enough to plow and blow or set out a couple bales and don't care what it looks like I have it. Use 2' x 6' 100% cotton material like denim or other flame resistant cloth for skirts covering engine to rear fenders so engine heat is directed onto operator's station. My brothers and I built them using nothing except old pick sacks and baling wire in the 50s. It kept us toasty warm 8 and 10 hours turning ground in February.
/ Soft cab enclosure for winter. #9
Thank you, and yes there's a very long (some would say boring) thread covering it from start to finish. We bought the L3200 in early 2012 and started the cab about 6 months later. The cab was nice, and with the doors off it was better than an open station in the Summer heat. However, when Wifey's brother suggested I'd live longer if I had a climate-controlled cab not having to breathe the dust and pollen. Late in 2018 we bought the L4240.
/ Soft cab enclosure for winter. #10
thanks very much. I'm going to read over it. Really nice looking cab that you built.
/ Soft cab enclosure for winter. #11
Key quote from your thread build:
"Not much of anything on it is anywhere near close to square, level, round or plumb. Like most tractors, the Kubota is a combination of different angled parts joined with French curves."
Now that you have a factory cab with AC, what is your opinion on doing a DIY cab versus the factory cab?
/ Soft cab enclosure for winter. #12
You might give Original Tractor Cabs a call. They don't seem to list your particular model but I think they sometimes have things available that aren't listed on the web site.
Hard Top Cabs
/ Soft cab enclosure for winter. #13
I wouldn't hesitate to build a cab if A/C wasn't desired. I did some checking on adding A/C to the DIY cab. It wouldn't have been impossible - but darn near. Plus, I wanted to mow more than 6' wide and the L3200 didn't have the spare horses for a larger deck and A/C. My rough guess was +5HP for the A/C and +5HP for a wider RFM above the 32HP the L3200 had = 42HP. The L4240 fit that requirement.
There's no substitute for A/C for me, and the factory cab is way quieter. Obviously it is more comfortable with being able to pick the temperature inside the cab in any weather. It also eliminates coughing up "lung fung" the morning after stirring up dust and pollen. Depending upon the weather, there are often various bugs that seem to like heading for ears and eyes - particularly at night. For a few weeks each year there are deer flies that are a real nuisance.
The DIY cab's main purpose was to keep me warm and dry in the Winter. It did that very well. It was also a little more comfortable than open station tractors I've had (that didn't have canopies). Had 3 of them before the L3200 used in the project. With the doors removed and a small "bus driver" fan it was livable in the heat. Exposure to pollen and dust wasn't different from being on an open station.
Given a choice, I'd get a factory cab. Building the cab was a fun and sometimes challenging project. It was a lot of work compared with most of what I do. I love tinkering and making stuff.
/ Soft cab enclosure for winter. #15
I'm not aware of a specific aftermarket soft cab brand for Kioti tractors, but there might be options available in the market. You can try searching online or contacting Kioti dealerships or tractor accessory retailers for recommendations. Additionally, some tractor owners choose to customize or make their own soft cabs if they have the necessary skills and materials. It might be worth exploring both options to find the best solution for your specific Kioti tractor model.
/ Soft cab enclosure for winter. #16
covermytractor.com seems to have quite a few soft cabs for different makes and models. They also have storage covers if you aren't going to be using them.
/ Soft cab enclosure for winter. #17
For winter operation when you have an open station, is it feasible to dress like you are going for a motorcycle ride? I own several items of outer clothing sold by Gerbing, and they could easily be used on a tractor. The smaller charging system of a motorcycle will support the electric clothing, so I am sure most tractors will put out enough power to run 12volt clothing.
Putting on electric clothes is a lot easier than building a cab!
David from jax
/ Soft cab enclosure for winter. #18
David from jax
I would think so. On my open station tractor the prvious owner intalled a piece of Polycarbonate from the canopy to the dash to cut down on the wind and blown snow when he was plowing snow. He plowed in Carhartt insulated overalls.
/ Soft cab enclosure for winter. #19
David from jax
For my last several winter seasons in an open station tractor I used my Gerbing heated gear - Vest, pants, and gloves. I may have used the socks also, but I don't recall. The only issue was the tops of my legs would get wet from melted blown snow even through some supposedly water proof outer gear.
After 9 years in a climate controlled cab there's no going back!
/ Soft cab enclosure for winter. #20
Anti-fogging, use RainX on the inside. The instructions say not to use it on the inside of a windshield, but I did.
I used it during cold wet conditions that caused the MH windshield to fog badly, I had to place towels at the bottom to collect the water that beaded-up and ran down instead of fogging-up the windshield. It performs the same whether inside or outside of a window.
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2016 Cadillac XTS Sedan (A64557)
2016 Cadillac XTS...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
