New (used) IH 7500 Dump Truck purchase, modification & fix up
   / New (used) IH 7500 Dump Truck purchase, modification & fix up
$900 to repack. I think a lot of the cost is to remove it and reinstall it, too
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #332
That sounds a bit more reasonable, they're a pia to remove, more so to install.
I need wheel help/suggestions.
The wheels are scaly rust and look terrible.
Need to decide which direction to take this. I’d like to go with 385/65/22.5 floats up front. The rear tires are fine. US made Goodyears with lots of tread.
The front wheels would need to be a wide base wheel, but I don’t know about offsets.
How do I get the handle holes to match on front and rear wheels if they are different size?
Where‘s a good place to find clean used?
I don’t even want to think about aluminum wheels
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #334
I believe Service Tire sells new and used rims that have been blasted and powder coated.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #335
As for the fender flares, try the heat route, it works wonders.
I was just going to suggest that, it's amazing what you can do with a heat gun and a little time.
Aaron Z
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #336
Jessie Mueller did a video on buying and installing a tarp kit for his dump a while back might be helpful to see the problems, he ran into, so you don't. 🍻
An electric tarp is north of $2,000 now (installed). I think that’s ridiculous.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #338
All the individual parts prices are ridiculous when you look at them, the reversing relay is $50 on Amazon, probably well over $100 if you go with a brand name, Cole Hersee for example, the 40'+ of 14/2 6ga copper wire if you get it from a reputable place rather than soy covered, copper tinned aluminum China crap etc...etc. Then you add on the 3± labour at $100-$120 and hour. Wouldn't hazard a guess what the motor's worth.
A few pics I grabbed while it was sitting outside.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #340
INOP Kawasaki Bayou 250 Four Wheeler (A57453)
INOP Kawasaki...
2006 New Holland LS180 (A55272)
2006 New Holland...
2016 Ford F-250 4x4 Ext. Cab Reading Service Truck (A56858)
2016 Ford F-250...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
6ft American Flag Metal Rooster (A57454)
6ft American Flag...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
