New (used) IH 7500 Dump Truck purchase, modification & fix up
   / New (used) IH 7500 Dump Truck purchase, modification & fix up
$900 to repack. I think a lot of the cost is to remove it and reinstall it, too
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #332
That sounds a bit more reasonable, they're a pia to remove, more so to install.
I need wheel help/suggestions.
The wheels are scaly rust and look terrible.
Need to decide which direction to take this. I’d like to go with 385/65/22.5 floats up front. The rear tires are fine. US made Goodyears with lots of tread.
The front wheels would need to be a wide base wheel, but I don’t know about offsets.
How do I get the handle holes to match on front and rear wheels if they are different size?
Where‘s a good place to find clean used?
I don’t even want to think about aluminum wheels
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #334
I believe Service Tire sells new and used rims that have been blasted and powder coated.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #335
As for the fender flares, try the heat route, it works wonders.
I was just going to suggest that, it's amazing what you can do with a heat gun and a little time.
Aaron Z
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #336
Jessie Mueller did a video on buying and installing a tarp kit for his dump a while back might be helpful to see the problems, he ran into, so you don't. 🍻
An electric tarp is north of $2,000 now (installed). I think that’s ridiculous.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #338
All the individual parts prices are ridiculous when you look at them, the reversing relay is $50 on Amazon, probably well over $100 if you go with a brand name, Cole Hersee for example, the 40'+ of 14/2 6ga copper wire if you get it from a reputable place rather than soy covered, copper tinned aluminum China crap etc...etc. Then you add on the 3± labour at $100-$120 and hour. Wouldn't hazard a guess what the motor's worth.
A few pics I grabbed while it was sitting outside.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #340
International S1900 (A56436)
International...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
2001 Dorsey DOTS48 48ft 39 Ton T/A Flatbed Trailer (A56858)
2001 Dorsey DOTS48...
2008 Ford Econoline Wagon Van, VIN # 1FBSS31L98DB22734 (A57453)
2008 Ford...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
