Looking for a 2000s model tractor with a loader. What brand?
   / Looking for a 2000s model tractor with a loader. What brand? #1
presta24
cincy
1948 8N, 2021 CK2610
Looking to get an older tractor that at least has a loader. I have a CK2610 now and would like something similiar in size. No larger. What brand tractor should I go with? Live PTO a must.
   / Looking for a 2000s model tractor with a loader. What brand? #2
That’s a pretty wide open question, there is a lot of good tractors. I would prefer a John Deere or Kubota but lots of others out there.
   / Looking for a 2000s model tractor with a loader. What brand? #3
I am personally a Kubota fan, as they have served me well over the past 25 years. Currently own an L4060, ZD326, and ZD1211. They are all reliable and well made.
I would venture to say that most tractors on the market today are of similar quality, the real difference being parts and service availability.
Happy shopping!
   / Looking for a 2000s model tractor with a loader. What brand? #4
Check tractorhouse.com for ideas.
   / Looking for a 2000s model tractor with a loader. What brand? #5
I am very happy with my LS MT225s which is just full of amenities. Bought it new in 2020 for $15.5k. No need to spend big bucks to get a fine product.
   / Looking for a 2000s model tractor with a loader. What brand? #6
What is wrong with your current tractor? Why do you want one from 2000s?
   / Looking for a 2000s model tractor with a loader. What brand? #7
Do you need a 2nd for another location, a back up machine, or is there something you need that the Kioti doesn't do? Physical size, most of Kubuta L series fit the bill. Are you happy with Kioti?
Want something I am less concerned about beating on. Trying to keep the yote nice-ish
Just a back up. I'm pretty happy with the kioti. Ive put 250hrs on it on 1.5 yrs and she's never sputtered. Expected her lift capacity would be better but I haven't used a similar size machine in any other color so cant really compare to anything.
   / Looking for a 2000s model tractor with a loader. What brand? #10
No specific model suggestion; but if you can work with a 2WD, gear, machine, and Ag or Turf tires, those machines will be less desirable, and cheaper, as a back up machine. Since you have a small-low HP machine, I would be more inclined towards a 2nd machine, with more HP, and Ag tires. I like my CK2610, but I'd I was to buy a 2nd machine, I would look at 40-60hp machines, with less modern convenience, to gain some more coverage. I wouldn't want a 2nd CUT, similar spec, on same property, as I can only operate one at a time. Basically, I would want to add a capability that I don't already have, if that makes sense.
   / Looking for a 2000s model tractor with a loader. What brand? #11
Massey went through some weird, very short run models in the 90s, and they are almost orphan models. I'm sure others did as well, as they changed builders, ect. I would look for a machine that was manufactured for atleast a 4 year run. Remember yellow/black Yanmars, sold as Challengers, that only lasted a couple years, and from what I understand, it's a real crap shoot on what parts you can find, and cross reference. Montana Tractors, several others, and you know at some point, you Will need parts, even if it's just a starter or steering parts, let alone an injection pump or something like that.
   / Looking for a 2000s model tractor with a loader. What brand? #12
If you are looking for a subcompact you could look at a Steiner 420 with a Onan (older but still repairable or upgradable to a newer engine) like I have. I have the full loader and they can also be had with a slip scoop which is cheap and functions as a semi loader (no height lifting but scooping capability). These machines used are around the 3-5k range now and I see them advertised around me quite a bit lately. Mine is a 1994 model and it's still going strong with around 800 hrs on it with the original Onan 20hp Performer.
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
2011 Freightliner Cascadia 113 S/A Day Cab Truck Tractor (A59230)
2011 Freightliner...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
Mini John Deere Truck (A55853)
Mini John Deere...
207281 (A52708)
207281 (A52708)
