farmtrac 360DTC
/ farmtrac 360DTC #1
fullofquestions
FT360DTC-S/N360DF4AG0166
I have a Farmtrac 360DTC S/N 360DF4AG0166, not sure what year it is. Just bought it. I really need a wiring diagram. None of the lights work on the dash or headlights, turn signal, or emergency flashers . Fuel gage doesn't work, charge light, oil pressure light, glow plug indicator, hyd. oil filter, parking brake , power take off and high beam light are all not working. so I really need a wiring diagram so I can start chasing wires and checking grounds. Any help out there? I am a mechanic on aircraft so I can chase this problem without a diagram but it will take much longer to find the problem or problems. Any help would be much appreciated.
/ farmtrac 360DTC #2
I have no schematic but does the tractor start and run normally? Do you have power to the fuse box? Is there a fusible link somewhere?
/ farmtrac 360DTC #3
Sir I am an old wire out wireman and I wish I was there to help. Wireing diagrams are useless to me on that type equipment. Most of the time athey are not schematic, but just the elemtary and very difficult to follow. Yea I be exactly like you and make sure that ground was there and they might break it in a safety switch or something. Then you might get a temporary positive and touch around and get a little motivation. Stay in touch and good luck sir
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
2001 FORD F-250 SUPER DUTY (A67714)
2001 FORD F-250...
2000 Mack DM690S T/A 2,000 Gallon Water Truck (A66736)
2000 Mack DM690S...
2011 TORO SP5040 MOWER (A66091)
2011 TORO SP5040...
1998 CAT 938G WHEEL LOADER (A67714)
1998 CAT 938G...
