Fixing a New Holland weld
/ Fixing a New Holland weld #1
OFarrell
NH Workmaster 60
How would fix this busted weld? This is the loader support bracket on a New Holland Workmaster 60. I think it's been broken for a while but I never noticed it.
I was thinking remove the loader and pull the bracket off the tractor frame so I don't have to weld upside down. I'll be using an old 200 amp Lincoln with .035 ER70S-6 wire and 75/25 argon.
/ Fixing a New Holland weld #2
It might be worth a trip to the local welding/fab shop with a "heavier" welder, especially for this major load area. The last thing you want is to do this again. Oh, and I suck at vertical and overhead also. 😆
/ Fixing a New Holland weld #3
I would clean it up and tack it really good while still mounted. Then remove for welding up solid. Slow and steady is the key here.
/ Fixing a New Holland weld #5
Go for it. Grind it out, crank up your welder and make a few passes. It’s not a critical joint, keep an eye on it and address it if it cracks again. Looks like the original weld didn’t have any penitration.
/ Fixing a New Holland weld #6
I take this "loader support bracket" as the mounting of the loader "tower". If it is, that's as critical as it gets on a FEL. It'll make a huge mess of the bracketry if one side lets go and probably involve sheet metal and more.
/ Fixing a New Holland weld #8
No reason why you can't MIG weld it. Like others said tack it before removing, clean it up real good, turn it up to get good penetration and go slow. Take a good pause on the left and right sides of your bead. The main thing is penetration. A few passes over-lapping about 50% want hurt. I would also look at the other side and make sure it has good penetration. If you don't like the what you see you can always take it to a shop or have someone weld it in place. Good luck!
/ Fixing a New Holland weld #9
Biggest downside to MIG is lack of penetration with the machines commonly used by hobbyists/part time welders. A MIG machine that'll do that right costs $2000+ used. A stick machine that'll do it costs less than $500.
/ Fixing a New Holland weld #10
You are 100% correct and I agree. He referenced he was using a 200amp machine.
/ Fixing a New Holland weld #11
I have to disagree with you, that a $2000+ must be used to get proper penetration with a MIG welder. I have properly welded plenty of 5/16" inch thick steel with my 115 Lincoln SP125 PLUS MIG welder. By properly I mean the proper amount of penetration. The way to do this requires pre-heating the work before welding.
Eric
/ Fixing a New Holland weld #12
Eric
Could be. I haven't tried that. Couple things though. One, preheating something like that is going to be quite the hassle, and two, I'll bet that tube is quite a bit thicker than 5/16. Anyway, as Arayt reminded me, the OP has a 200 amp welder, so he/she should be good to go. (y)
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2015 Isuzu NPR-HD Box Truck, VIN # 54DC4W1B3FS807576 (A65563)
2015 Isuzu NPR-HD...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
Volvo VNM (A63689)
Volvo VNM (A63689)
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
New/Unused Wolverine 78in Quick Attach Rock Bucket (A65583)
New/Unused...
