100 hour maintenance
/ 100 hour maintenance #1
BruceS_55
RK25
There are some items on the 100 hour maintenance checklist for my 2515H that I don't understand. Does anyone know what the engine breed pipe is? I'm supposed to check it. Also, what is the steering wheel hose? Is it some kind of power steering fluid hose?
/ 100 hour maintenance #2
I don't know, but you better put on "protection" before you start.
/ 100 hour maintenance #3
Not sure what it is referencing, but besides the major 50h service chassis lube and general check hoses, nuts and bolts and fluids goes as far as maintenance schedule in user manual should be sufficient.
/ 100 hour maintenance #4
Does it refer to a crankcase breather tube? Just checking it isn't blocked up?
/ 100 hour maintenance #5
See parts diagram below
/ 100 hour maintenance #7
My assumption for steer wheel pipe is just check your power steering hydralic lines.
/ 100 hour maintenance #8
I wonder if @Asteral could clear up any confusion. He is pretty knowledgeable about the models formerly labeled Branson.
As for the "breed" pipe, it's probably a misprint but I'm not sure what it should be.
/ 100 hour maintenance #10
It's the crankcase breather. Just make sure the tube/pipe isn't clogged by debris.
/ 100 hour maintenance #11
Chinese, and some early Japanese, translations are often amusing.
The worst one I remember said to "clean out the cock with a stiff brush". Had to do with the radiator on a Nissan Patrol.
/ 100 hour maintenance #13
My dealer salesman told that since I’m a do it yourselfer type that I should consider spending the $400 on a factory shop manual.
/ 100 hour maintenance #14
Even at that crazy inflated price it would be a time and money saver. If you haven't already bought it, I would look around for a searchable pdf shop manual. I found one for my Kubota for around $20.
I paid like $200 for a shop manual for my previous Kubota, and the Kubota dealer did a poor copy machine job and put it in a dollar store binder.
/ 100 hour maintenance #16
Probably but sometimes it’s worth spending the money for good print.
Yeah I’d like to see one of their shop manuals before I bought one.
I just hate PDF manuals…..I guess I’m old school.
/ 100 hour maintenance #17
WESTFIELD WR641 - 6" X 41' GRAIN AUGER (A64278)
WESTFIELD WR641 -...
Bull (A64557)
Bull (A64557)
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2018 CATERPILLAR 303E CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2025 LandHonor RGB-11-72W 72in Hydraulic Dual Cylinder Rock Grapple Bucket Skid Steer Attachment (A64553)
2025 LandHonor...
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A64553)
2007 JLG 600HJ...
