Hyakkimaru16
- Joined
- Aug 13, 2023
- Messages
- 9
- Tractor
- Multiple small Kubota diesel engine machines
My name is Tristan and this will be my first thread on this site but, I'm excited to meet everybody. I have a Lincoln ranger 305d generator welder with a Kubota d722 3 cylinder diesel engine on it. I got it in a trade and I got other stuff as well but, I would like to get this thing working so it can be my new mobile welder rig. Well this particular engine comes with up to a 3,000 hour major engine parts warranty and I am barely over half of that. About 1800 hours. First thing I did was bleed all the air out of the fuel system and out of the injection system trying to crank it. Well after messing with it for quite a while and having no luck even spraying diesel directly into the intake, I did a compression test. Cylinder one, I assume it's cylinder one. It's on the flywheel side. 120 psi, cylinder 2 240 PSI, cylinder 3 350 PSI. Obviously there's problems. So I pull the motor and remove the head. The valves are rusted pretty good, and likely pitted although I have not removed them yet. The cylinders look like crap but I can't feel anything with my fingers. Everything feels smooth to the touch although it doesn't look great. A little while ago I was recommended to try some transmission fluid in the cylinders and turn it over with the starter for a bit to clean up some of the build up and see where I stand so, after doing that for about 10 minutes intermittently, this is what was left. Doesn't look great. The black spots at the top of the cylinders I can feel with my fingernail. I don't know if it's crud buildup or if it's a burn spot or what. I don't know if somebody ran gas through this thing, there's no telling. Again, the valves look terrible so I'm kind of tempted to rebuild the head and slap a head gasket on it and retest compression but, what do y'all think? I did make a short video showing off the cylinders and head before I did all of the stuff I've currently done and I will post a link to that as well. Let me know if you think I should just have the cylinders honed and put oversized Pistons or if I could get away with new standard pistons and rings and a light touch up hone or what. Let me know, thanks.
Everything but the first picture are from before turning it over with transmission fluid. The first picture is the after.
