T1760 Lawn Tractor Mower Problem
/ T1760 Lawn Tractor Mower Problem #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I might have the lawn tractor model number wrong, but is my best recollection.
My lawn tractor at my cottage has worked well for decades.
The grass has not been mowed in a couple of weeks and is now significantly overdue.
Today when I tried to engage the mowing lever, the mower would not start the blades as usual. Nothing happened.
The belt is good, and the pulleys seem ok from what I could initially see.
The main cable connecting the mower lever to the idler pulley works as intended.
One thing that is obviously something wrong is a second much smaller cable also connected to the same mower engagement lever is no longer connected to anything. It most likely broke from old age.
Does anyone know what this smaller cable is supposed to be connected to, and what it does?
Any other ideas of why the mower will not engage when intended?
TIA
Yooper Dave
/ T1760 Lawn Tractor Mower Problem #2
Likely the brake cable which pulls the pad away
/ T1760 Lawn Tractor Mower Problem #3
TIA
Yooper Dave
Could you confirm the tractor model number and maybe post some photos of the things you described.
Richard
Richard
Sorry - cottage is out of town and I am in the middle of moving. I do think I have the model number correct though.
Thanks
Yooper Dave
BUNDLE OF APRROX (45) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2015 Ford F-350...
2017 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2017 Ram 1500 4x4...
2016 Big Tex 50LA Double Axle Utility Trailer (A61165)
2016 Big Tex 50LA...
2003 Homemade 11ft S/A Trailer (A61569)
2003 Homemade 11ft...
2018 EH Wachs Trav L Vac Hydro Vacuum Excavator Trailer (A61567)
2018 EH Wachs Trav...
