'Professional' grade saws vs. 'Homeowner' saws
/ 'Professional' grade saws vs. 'Homeowner' saws
I have two chainsaws. Both are Stihl. Large one with a 20" bar - small one with a 14" bar. Surprising - as I get older I tend to use the smaller one - more and more. Just last month I had to use the large one to fell a couple "bug infested" pines. Both were 24" on the butt. Once on the ground - I immediately switched to the smaller saw.
I hear you on that one! Used to think a 24" bar was no big deal. Now I look for 18" or less. My current favorite is a little 2240 Jonsered with a 14" bar...of course that might be because it always starts.
I have an Echo 620P (p=professional).
Has magnesium for most stuff (including sprocket cover) my other Echos have aluminum or plastic.
No cat muffler.
Decompression valve for (much) easier starts.
Clutch driven oiler
Dual bumper spikes (very useful)
Upgraded coil
dual ring piston
An Echo might be my next saw. Very helpful if they tack a P onto the end of their Professional model numbers.
Unfamiliar with their models. That sounds like a big saw...certainly loaded with features. Do they make a Pro model around 40cc or high 30s?
/ 'Professional' grade saws vs. 'Homeowner' saws #23
They have some small "p" models in their new line. I am not familiar with the smaller pro models.
/ 'Professional' grade saws vs. 'Homeowner' saws #24
Be careful with a Makita chainsaw and note where they are made at. They can be Chinese or Japanese depending. The Echo Timber Bear is about 150 clams less btw and is a very popular 'pro grade' saw. I have one and it's easy to improve on the power output with some simple mods, plus Echo offers a 5 year non arborist use warranty.
I see the Echo at $600+ and the Makita at $650.
Only the 60cc saws are being considered. (only one model Makita, with different bar length options.)
/ 'Professional' grade saws vs. 'Homeowner' saws #25
620p has 20", 24" (which I have) and 27" as options, The 24" is well balanced in the cut.
The saw is a bit heavier than the competing Husqy or Stihl for the HP, but about half the price.
The Makita's have a great reputation, but I don't see any tree people using them, and Makita is getting out of the gas saw business.
Though all the manufacturers have battery saws in the smaller sizes.
/ 'Professional' grade saws vs. 'Homeowner' saws #26
In addition to lighter weight and more power, the pro saws in Stihls lineup have compression releases, better air filtration, better anti vibe and slightly better ergonomics. For a few hundred $ more, they're nicer to run. But the homeowner and ranch saws work fine and will get the job done.
The homeowner saws often have open ports- the transfer ports are basically just troughs in the side of the cylinder. The pro saws have closed ports with a better shape which means better flow and thus better power. They're still pretty rudimentary compared to motorcycles though. Clamshell saws can be rebuilt just as well as saws with separate crankcases and cylinders, they're just different.
/ 'Professional' grade saws vs. 'Homeowner' saws #27
Makita bought the German made Saks Dolmar. I have one of the last blue 50cc professional model. Great saw, but you'll end up with an orphan, Makita is going to or has already stopped making any gas-powered equipment.
I like the Echo or Husqvarna pro stuff.
/ 'Professional' grade saws vs. 'Homeowner' saws #28
Still can rebuild both the plastic cased and the better mag cased saws. It's just if you only need to do a piston change on mag cased just pop the cylinder and remove piston.
Plastic cased saws most times (unless efco and some other small saws) you have a clamshell and will be removing crank etc etc to just do a easy job.
First mag case easy piston swap.
New clammy shown without crank, bearings, seals etc.
/ 'Professional' grade saws vs. 'Homeowner' saws #29
That applies to all the orphan saws like McColugh and Poulan as well. The older they get the harder it is to find parts (except the cheaper Chinese on Amazon parts) that may or may not work.
Me, I like any saw with a local dealer presence, except Husky and TSC because TSC don't have a clue about service in the first place.
/ 'Professional' grade saws vs. 'Homeowner' saws #30
One more option to muddy the waters. I have had three Dolmars. Fairly good saws but when I needed parts they were not available, obsolete. I’ve had two Stihls, older models which ran great. I currently have four Huskies that are all pro saws, XP’s. Two are 26 years old and the other two about 10 years old. I did replace the piston and cylinder on my 272XP two years ago, never done any carb work on any of them.
The pro saws today all have computers controlling fuel delivery. One of the issues with them is if the saw sits for a period of time sometimes they won’t start and that requires a trip back to the shop to have the computer reflashed, normally a $100.00 charge.
Stihl makes a 362 without the computer, and the last I knew it was a metal case saw. The 362C has the computer controlled carb. I think that would be my next saw, they are a bit pricey but I think worth it.
Randy
/ 'Professional' grade saws vs. 'Homeowner' saws #31
If you were to buy a small saw, but would get used hard occasionally, what do y’all think about a Stihl MS170?
Askin for a friend….
/ 'Professional' grade saws vs. 'Homeowner' saws #32
I need to re-ring the Pro-Mac 10-10, the pull is getting soft.
Rings are cheap, it's getting them in place that slows me down ;-)
/ 'Professional' grade saws vs. 'Homeowner' saws #33
I have a couple of Pro Husqvarnas with modded mufflers. I like them a lot but not the cost of new. I have a used top handle Echo, and a woods ported Echo CS4910. I like the light weight, performance, quality and price of the Echos.
/ 'Professional' grade saws vs. 'Homeowner' saws #34
Not correct. Maybe Stihl with their E-tronic system but not Husky and certainly not Echo, though both can be bought with electronic fuel injection.
The Echo pro saws are all carbureted (Walbro). The differentiation between the Echo home owner and pro saws is, the home owner saws will have a cat in the muffler can whereas the 'pro saws' don't and the pro saws aren't clamshell either. Easy to tell, just look under the muffler can and see how the jug attaches to the 'crankcase' and look in the muffler can, the Cat will be visible behind the exhaust deflector, under the spark arrestor screen, plus the Echo 'pro saws will come with Echo's I-30 easy start system.
I have 3 echo's, a Timber Wolf, a CS top handle arborist saw and an Echo straight shaft brush trimmer.
The CS top handle has to be the absolute best buy in top handle arborist saws today. They are basically 1/2 the price of the Stihl (had one of them and smashed it under the chipper truck tire). Stock, they are a little down on power until fully broken in (couple tanks of fuel) and all Echo saws are made in Japan with quality Japanese assembly. Finally, a hard to beat warranty as well. 5 years consumer use, 1 year commercial.
I do suggest purchasing an aftermarket can for them. Saw-it-Again carries both the Forrester can as well as the OEM (gutted) can. Not that much jack either and of course remove the EPA mandated limiter caps on any saw.
Down to exactly ONE Stihl now that I use a lot. My ancient 028. the big ones 090 and 075 are shelf queens.
/ 'Professional' grade saws vs. 'Homeowner' saws #35
/ 'Professional' grade saws vs. 'Homeowner' saws #36
I have a Husqvarna 572XP with a 30'' bar for biggins, then a smaller 435 with a 16 bar for delimbing very well.
/ 'Professional' grade saws vs. 'Homeowner' saws #37
I have no use for anything over 20" and if I do, I borrow my buddy's Dolmar with it's 30" bar. Like I said, my big ones are shelf queens, devoid of gas and bar oil as well and the jugs are fogged.
/ 'Professional' grade saws vs. 'Homeowner' saws #39
I believe (not 100% sure) that Echo does offer a FI saw, not that I'd have one, I don't cotton to any FI motor and that includes farm tractors as well.
Show me a FI echo saw sold in US today. He is talking saws sold today right now.
/ 'Professional' grade saws vs. 'Homeowner' saws #40
Like I said, not 100% certain. I need to peruse their website to find out for sure... I do see that Echo, like Stihl and Husky is pushing the electric (battery powered) saws. Not something I'm at all interested in except maybe a pole saw and certainly not a brush cutter.
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2017 Ford F-550 Ext. Cab Enclosed Service Truck (A61568)
2017 Ford F-550...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
