PTO Chipper Advice -- maneuverability and center of gravity concerns
   / PTO Chipper Advice -- maneuverability and center of gravity concerns #21
I've a (now 10 yr old) Jinma 8" chipper, no rotating chute..
I know it's a "bottom of the line" chipper but I bought it new for a very good price (?$1500?) and it was cheaper than taking what I was clearing to the dump, plus we needed the chips.
Anyways - Concerning the rotating chute problem.
@rswyan was in the process of modifying his for a rotating chute, so that might not be very difficult to do for the WoodMaxx MX-8500G+.
massive thread here
Your chipping sticks small enough that you where mowing them with a brush hog?
I cut off everything that is bigger than 2.5 inches and that's what I hit with the brush hog. Everything else is either cut up for firewood or piled up for when we rent a chipper. I have way too much firewood already and we need to stay on top of fire mitigation, so it's time to upgrade.
   / PTO Chipper Advice -- maneuverability and center of gravity concerns #23
While I'll agree that the Vermeer is a better unit, you're the first person I've heard that called the 8M (or 8H) units a 'tin can'. The 8H weighs in at over 900 lbs.
Plus, I think the Vermeer requires at least 28hp....
How many other people have upgraded to a vermeer 606/906 from any of the other pto units? The woodmaxx is absolutely a tin can vs the vermeer. The 8h might be 900lbs, but the 906 is 2150lbs and a 606 is 1400lbs. The folding part of the feed chute is 3/16" thick alone. I'd be happy to add some comparison photos on my 906 thread of the build differences if you're genuinely curious.
You could absolutely run a 606 with 24hp, just slow feed on big stuff or pause it for a moment. That's the beauty of a hydraulic infeed chipper.
A HUGE thank you to everyone who responded. Very appreciated! My conclusions so far:
1. Wheel spacers are a must-have
2. A power feed is a must-have
3. A fully rotating chute is a must-have
4. A flat intake is a really nice-to-have
5. Since no one has said it will be a problem, I'm assuming a PTO chipper won't make the tractor more tippy (I hope 😅). Again, I'm not interested in going to new or more dangerous places; I just don't want the places I already go to be more dangerous with a heavy chipper on the back (y)
So.... I'm still researching and will call a couple of companies tomorrow. My current top picks are now powered models from WoodMaxx and Woodland Mills. I'm leaning towards WoodMaxx pretty heavily, but they are a way pricey compared to the Woodland Mills.
   / PTO Chipper Advice -- maneuverability and center of gravity concerns #25
I'm repeating myself...........but....... the heavy rear PTO chippers make the front end really light when moving from place to place.........Thus some kind of ballast on the front end such a FEL makes the tractor more stable when moving from place to place. This is especially noticeable on the smaller CUTs....as to the OP's original question as to stability, manueverability and center of gravity. ....... in my experience.
Cheers,
Mike
   / PTO Chipper Advice -- maneuverability and center of gravity concerns #26
I have the Woodmaxx WM-8H. haven't used it much yet, just got it, but it does work well. My tractor is a 38hp, L3600 Kubota with a loader. I really like the hydraulic feed and the feed chute. I can't image not having a rotating discharge chute. I have been blowing it in my truck bed to haul where the wife wants it. The unit is heavy and fairly long, I have to watch to make sure I don't drag in uneven spots.It does have good skids for feed, unit is very stable when using it set on the ground. WIll be using it for white pine limbs and slabs from the sawmill, with some hardwood in the mix. I have steep hills, don't think it made the tractor more tippy. With smaller tractors I really recommend wheel spacers, weights and loaded tires, make a big difference on my BX2230.
Cheers,
Mike
The extra weight on the back makes for a good point on stability. I've definitely had problems in the reverse with a full load of dirt -- bounce and side-to-side which I'm hoping spacers will help with. I think it's a 1/2 yard bucket (?) and I always have the brush hog on the back (about 400lbs). Even with the FEL at the lowest height I can get away with and still go over bumps, side to side going across even a really tiny grade can be dicey, so I limit dirt to a 1/2 load in bad spots. As for weight in just the rear, no problems so far with the 400lbs and an empty FEL. But, the MX-8800 chipper, for example, would up the rear weight to 770lbs, so front end ballast could very well come into play.
   / PTO Chipper Advice -- maneuverability and center of gravity concerns #28
I have a Bearcat SC5540B on my Kubota L2550 & have no stability issues although I have not taken it on any really steep inclines. It works like a champ.
   / PTO Chipper Advice -- maneuverability and center of gravity concerns #29
I have a Woodland Mills 8” on a 955 JD. The tractor weighs around 2000, and the chipper around 1000. So, it’s a load. If you have a tractor in the 25 hp area a 6” chipper might be enough, as my 33hp Deere has its hands full. Weight wise it’s tippy, but can be handled with CARE. Meaning no driving across side hills, and making sure you go slow. Regardless o a chipper on the back of a tractor that size is going to be "tippy".
   / PTO Chipper Advice -- maneuverability and center of gravity concerns #30
The type of saw will be the least of your worries if you roll the machine.
What is so important about the underbrush that you would risk it??? DUH>
Good enough is Done.
2018 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
LOT: (8) Chain Binders (A59076)
LOT: (8) Chain...
1604 (A57192)
1604 (A57192)
