Is my hydraulic pump dead? (Tx1300F)
/ Is my hydraulic pump dead? (Tx1300F) #1
Norwegian Viking
Iseki TX1300F
Hallo
I just bought a Tx 1300F that had been sitting for 10 years so i got it quite cheap compared to other Isekis with a FEL ( But maybe not cheap enough)
With a little bit of coaxing i got the engine started so i knew that was working when i got it home. I have avoided running it before i could do a service.
First up was changing all the fluids and found some issues with the gear/hydraulic fluid.
It had water in the oil and the filter for the hydraulic was dissolved and i found some pieces/teeth for the third gear for the PTO in the bottom of the gearbox.
And surprise, i cant get any circulation from the pump. let alone pressure. I can get it to work for a few minutes, then it stops working. I seem to get some oil coming through the return for the FEL in the start but it stops after a few minutes.
The 3 point has not been going down on its own when it sat in the raised position while i was waiting for parts. I have managed to get it raised a few times.
Tried the bleed port next to the speed control leaver for the 3 point. That did nothing. The pump also gets warmish with the engine running for only a few minutes.
Disconnected the outlet and ran the starter. I get some oil coming through but not a lot and it seem to come in bursts, not a steady flow.
Is there anything special you have to do after a hydraulic oil change that i'm missing or is the pump dead?
With the filter completly ruined it has been eating gravel for dinner so its no wonder if its dead.
/ Is my hydraulic pump dead? (Tx1300F) #2
I could be wrong but I believe those tractors have a screen/strainer on the suction side of the hydraulic pump. Did you pull that out to give a good cleaning?
As i said in my post.
That filter was completly destroyed. The screen was all mangled up. No idea how that could have happened. So the pump probably has been running without a function filter.
/ Is my hydraulic pump dead? (Tx1300F) #4
If there is no screen there is a good possibility the pump is shot. I usually supply an external screw on filter in these situations. I may have a used pump or can supply a new one.
That would have been really nice. Sadly i live in Norway, so shipping will be a hassle. Bought a new pump now so hopefully everything works.
/ Is my hydraulic pump dead? (Tx1300F) #6
Can i ask where in Europe you bought it? I live in Poland, and it looks like i have the same problem....
thx
M.
/ Is my hydraulic pump dead? (Tx1300F) #7
The 3pt getting stuck is probably from it sitting and the seals are dried out and/or the cylinder has rust in it.
Hope you get all of the water out of the system before you get your new pump installed.
/ Is my hydraulic pump dead? (Tx1300F) #8
I ship internationally by post since 1997. Hasn't been a problem.
/ Is my hydraulic pump dead? (Tx1300F) #9
Offshore (especially EU countries) has gotten insanely expensive today as well as the cost of materials, why I removed all the pricing from my .com website and state ship price on request and I prefer NOT shipping via USPS International because the tracking is non-existent and often the package never arrives. UPS as well as Fed-Ex is much better though even more expensive, they have reliable tracking and the product actually gets there.
The issue with USPS besides the above is, you can insure it but getting a refund from the PO is tedious and very slow. Been there, did that.
So i got a new pump installed, changed the oil (again) and cleaned the filter. Hoked up the FEL on saturday and did a small testrun, everything was working fine.
Today i moved some dirt around and after about one hour the hydraulic started shaking/shuddering, both on the FEL and 3 point when raising either the FEL or the 3 point.
Thought maybe the filter was clogged so i drained the oil and took out the filter wich looked fine. Filled it back up and it was working for about one hour before it started shuddering/shaking again. Noticed that the oil flow from the return was intermittent as well.
What is going on here? Seems to happen when the pump is getting warm.
Is there a airleak on the suction side?
thx
M.
I bought my pump from a norwegian dealer.
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
KUBOTA MX5800 TRACTOR (A62130)
KUBOTA MX5800...
Coats 5060AX Rim Clamp (A61307)
Coats 5060AX Rim...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
