Drawbar with down pressure
/ Drawbar with down pressure #1
Brian28
TYM25
I've got a TYM25 with 1.5 hours on it. While tendering hay with an old Grimm #8 that is quite center balanced, the tedder tips back and up comes the drawbar and hits the driveshaft from the PTO. I somewhat solved that problem, but now I wonder how your going to use this tractor do hill up a row of potatoes without having downward pressure on the drawbar. I have not talked to the dealer yet, but I might have the wrong tractor for my needs. What's your thoughts?
/ Drawbar with down pressure #2
I'm not familiar with your tractor but from your description you are pulling from a drawbar mounted to the lift arms. You should have a fixed drawbar lower under the belly of the tractor, low under the rear axle housing.
You are correct. That might be a possibility with the tedder. If I hookup my 5 foot tiller, do I just rely on the weight of the tiller to dig in? I picture it bouncing stop the ground. My old Ford 1500 has down pressure on the 3 pt hitch and I can dig in.
/ Drawbar with down pressure #4
Yes the weight of a 3 point implement is what applies the down pressure.
I wasn't aware that the little imported Fords had down pressure on the 3 point.
/ Drawbar with down pressure #5
I also am unaware that a Ford 1500 tractor has down pressure on 3 pt draft arms. Some Tractors built by Belarus have 3pt down pressure
/ Drawbar with down pressure #6
If you intend to use a drawbar mounted to the 3 point lift arms then you need to put some "Stay Bars" on it to keep the drawbar stabil. Here is a pic of some on an old Ford, they are usually available at most farm stores and are adjustable so they can be used on almost any tractor with a (Cat1) 3 point lift.
Makes sense. Good to know. I still wonder how to fill a row of potatoes without that downward force. You need to dig in to get enough soil to and cover the row.
/ Drawbar with down pressure #8
Can you post a photo of the Grimm #8? I don't see how you can pull any Grimm equipment with a 24hp tractor. I don't think my 50hp tractor could pull any of them. I know there's potato plows and disks but they're for single-row gardening. Even those will need loose soil for 24hp.
/ Drawbar with down pressure #9
The plow provides the down force. You can adjust the 'angle of attack' by varying the length of the top link. This is very important with a moldboard plow.
Yes I can post a photo when I get back down to the field. It fits fine.
Well Lou, I learned something today. My Ford 1500 does not have downward pressure. I was dumbfounded to learn that. How wrong I was.
Jim, as I mentioned to Lou, I was wrong thinking that mine did. I checked it and was a little surprised.
When I got my tractor back to the yard, I completely forgot to take a photo of the T25 with the Model 8 tedder on it. I did get a chance to take a photo of it in the Ford 1500. It's basically the same except the color of blue instead of red.
/ Drawbar with down pressure #14
You need to till the ground next to the rows if it's too hard for the hiller to dig in. I have that problem here, the ground gets hard after a few rain storms so that it's impossible to hill a row or even pull weeds.
/ Drawbar with down pressure #15
Oh yeah. I got totally off subject when you mentioned your potato farm. 🥺 I was thinking of the larger Grimm planters and such. My apologies for misreading your post. I'll go along with the others and state you should be pulling that tedder with a fixed drawbar or use the stays as suggested.
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
(4) Wheels and Tires (A65640)
(4) Wheels and...
Quick Attach Backing Plate (A65579)
Quick Attach...
Gehl Mix-All 95 Grinder-Mixer (A66408)
Gehl Mix-All 95...
Landhero Backpack Leaf Blower (A66408)
Landhero Backpack...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
